Thread: My levels after some adjustments
    May 2013
    South Florida
    55
    I've added muriatic acid and cyanuric acid to balance the pH and CYA. Here are my current readings:
    FC 6.5
    CC 0.0
    CYA ~85-87
    pH 7.5
    TA 70
    CH 250
    So, I know I need to lower the FC. Everything else look good? We're entering the sunnier/hotter/humid/rainy season here in South Florida.
    Any recommendations out there for the FC target level for my situation? I'm thinking of targeting 4-4.5. How does that sound?
    I'm currently running my SWG at 30% with the pool pump at 8 hrs/day. I was just linked to a study done here in South Florida that showed decreasing the pump run time to below 4 hrs/day showed no decrease in water quality or need for more chemicals. I plan to mess with the pump run time and SWG % until I get it just right. It seems as though the 8 hrs recommended to me by the pool store installer was WAY too much, huh?!
    I'm learning a lot here! Thanks everyone!
    15K gal, IG plaster, screened, Marathon Electric 1 HP single speed pump, Hayward c-900 cartridge, Hayward SwimPure 40K SWG
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: My levels after some adjustments
    Check this chart out.
    This will give a better idea of where you need to be on your FC. Tried and true levels.
    May 2013
    South Florida
    55
    Okay, thanks. I don't need to drain if my CYA is 85, do I?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Quote Originally Posted by doglover78
    You just added the expensive liquid CYA, why would you want to drain it the next day? Didn't I advise you to shoot low?
    You will lose some CYA to backwashing and splashout. Don't add anymore, and don't be using trichlor pucks, either! You're already too low on FC. You'll be needing to maintain FC between 7 and 10 from here on out. If you let it fall too low, you're begging for an algae bloom, and with that CYA level, you'll be buying bleach by the barrel, not the jug, to clear it.
