Thread: BORATES INFO?
    BORATES INFO?
    Is there a summary or article on Borates on the forum? If so, I can't find it. I have a gap of knowlege on Borates and their source. I assume they are produced by adding "Borax" but not sure how the affects of adding them have on PH,TA, etc.
    All I found was this
    BORATES
    Borates can optionally be added to the pool to help control algae, reduce chlorine usage, buffer PH, and improve the look and feel of the water. The process of adding borates to your pool is beyond the scope of this article.
    Lizzieann,
    27x54 AGP with Waterfall, 18,500 gallons, Waterway Sand filter- Waterway 1.5 hp -1 speed pump , TF-100 test kit, BBB method.
    38,271
    Re: BORATES INFO?
    There is a sticky in Chem 201:
    so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html
    Might want to read this first though for some eye-witness accounts:
    i-just-read-all-23-pages-about-borates-t63543.html
