Results 1 to 9 of 9
Thread: This ain't my first rodeo...BUT!
    Hello again there everyone. I have had continued good luck with my pool after I found you a few years ago. But now not so good and I need advice. I have read back up on the basics and can't seem to figure it out. Husband left the pool cover off all winter and of course I am trying to open a pond. My levels have pretty much stayed the same for about 2 weeks...
    FC-24
    CC-1
    PH-7.2
    TA-80
    CH-340
    CYA-33
    It is trying to turn over but remains very cloudy and I am beginning to wonder if my Calcium is too high? I know we have trouble with calcium in our well. I have opened up the filter and checked the sand. No channeling so I cleaned it out and closed her back up. Pump is a new one installed last year by warranty company and runs fine. I have no way of replacing water due to the fact I would just replace it with the same. Does anyone have any suggestions of what I am overlooking?
    Sincerely,
    Frustrated and possibly divorced if this don't clear up.
    p.s. Dave...I am coming for my refill of R-0013
    Wake Forest,North Carolina
    AG, 21,200 gl., Pentaire 1HP 1 speed,Waterway sand filter,BBB
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: This ain't my first rodeo...BUT!
    Filter running 24/7? Are you SURE there's nothing lurking on the bottom you can't see-----piles of dead leaves and such?
    Filter is running 24/7. Has good output. In the middle (pool is dish) there may be a handful of leaves I can't reach to get out yet. That will be this weekend now I can see there are no dead critters in there.
    Apr 2010
    East Texas
    9,569
    There sure is an awful lot of dark area in that pic that looks suspicious to me that are not in the middle. Have you tried vacuuming to waste those areas that don't have a pile of leaves?
    I am VTW on a daily basis. There are a few spots left to clear but part of what you see is shadowing from the surrounding trees. I should try and take a pic over the weekend when I am home at full sun.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Besides possible leaves in the middle, steps like yours are notorious hideouts for algae.
    And I guessed before I scrolled down far enough to see that you had a sand filter. Adding some DE would be my third suggestion, after clearing debris and scrubbing the steps.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    First make sure you're shocking correctly.
    1. 24 FC for 2 weeks straight correct. Hasn't been lower during this time??
    2. No leaves or animals in the pool correct. Make darn sure.
    If so, maybe some floc will help the process?? Allow all the dead to fall to the ground, then vacuum to waste. It will be added cost, but should speed up the job.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Have you tried adding a little DE (a cup or so between backwashings) to your sand filter to improve its filtering ability ?
    So it's off to get some DE this morning. I have never used it before but I will give it a try. The floc scares the crud outta me but if the DE does not improve it that will be my next try. Thanks guys..will keep posting pics.
