Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Baquacil Conversion...Help!!
    Jun 2013
    Clarksville, Arkansas
    23
    We bought a house last year with a pool and the previous owners used Baquacil. We just stuck with the Baquacil because that was the first time we had ever dealt with a pool. The water turned hazy and eventually greenish with pink slime. We covered it up and didn't mess with it anymore until now. I started the conversion to chlorine last Friday. I have read through several forums on here and I am thinking I am doing everything right, but my water is still hazy! It went from brown to green to blue, but still hazy. I cannot see but a few inches down. I have been keeping the FC at 15, but it has been back down to around 7-7.5 in the mornings. I did order the Taylor K-2006 before I started. I am on my 40th jug of 121 oz bleach! I was able to test every hour last weekend and add bleach as needed. This week I have returned to work so I can only test and add bleach in the mornings and evenings. Here are my results from yesterday evening:
    FC- 1
    CC- 3.0
    Ph- 6.8
    TA- 50
    CH- 150
    Added more bleach...
    This morning I only tested the FC and CC because that's all I had time for
    FC-7.5
    CC- 2.0
    What do I need to do?
    13,500 gal, AG, sand filter(not sure of size or model#), 6-7 years old
    Jun 2013
    23
    Re: Baquacil Conversion...Help!!
    You are doing fine. The whole process does take a while. You appear to be solidly into the second phase, FC is holding overnight and CC levels are not too high. So you are making good progress.
    The next time FC is below 10 (probably the next time you test the water), adjust the PH up to around the 7.2 to 7.4 range.
    Other than that, keep adding chlorine up to an FC of 15, especially in the evenings when you are losing the least chlorine to sunlight. Because you are keeping almost half of your chlorine overnight, you are now losing more chlorine to sunlight than to the conversion during the day. That makes adding chlorine during the day much less efficient. The whole process will be over sooner if you continue adding chlorine during the day, but will be more cost effective if you switch to only adding chlorine in the evenings.
    Jun 2013
    23
    Thanks so much for your reply. The pictures are from the first day up until day 4 and the pool is still looking like the last picture. I was getting worried that maybe I was or was not doing something I needed to be doing. There was so much nasty stuff on the walls and bottom of the pool when I started...I wondered if that was keeping it from clearing up. I have been brushing it as much as I can and I have vacuumed to waste twice during this process, but I can't see if I'm missing anything bc it is so cloudy. I will adjust the ph this evening.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Love those pictures!!
    Welcome!
    Jun 2013
    23
    Okay guys, I have run into a problem. I've noticed the last couple of times when I have vacuumed to waste that after about 5 minutes a bunch of crud starts coming out of the return. I replaced the sand in my filter a few weeks ago before I planned to convert to chlorine. I noticed some sand in the bottom of the pool. Seems like when I start to vacuum the sand it all comes right back in the pool. What could be causing this?
    Jun 2013
    23
    Okay...I'm needing some help! This is day 18 of my conversion and I can't even see 2 inches into the pool! What gives?? I'm reading about everyone else's conversion process and it seems that it doesn't take this long. My water is blue and cloudy as all get out! I'm doing everything right. Is there something else that could be contributing to the cloudiness of my water?? Someone please answer! I'm nearly to the point of ripping that pool down! I am so frustrated.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,086
    When you add the bleach, what shock number are you aiming for?? Are you testing with a FAS/DPD test??
    Can we see current test results??
    Jul 2011
    Eastern Ohio
    7,086
    Ps......are there any signs that the users used the Baquacil CDX system??
    Jun 2013
    23
    We had the pool last year and never used the cdx. I do have the fas/dpd test. I will test in a bit and post the results.
    Jul 2011
    Eastern Ohio
    7,086
    Test the CC reading too.
    Often I suggest not testing for CC's as you know there is some if the pools green, but I'd like to rule something out.
    Jun 2013
    23
    Will do. I'm fixing to test so I will post results shortly.
    Jun 2013
    23
    Test results:
    FC 0
    CC 1
    Ph 6.8
    TA 50
    CH 160
    Jul 2011
    Eastern Ohio
    7,086
    You need to add 2.5gallons ( 315oz ) of 8% bleach. How often are you testing and re-dosing during this process? The more you can test/shock the faster this process will go.
    edit: Start by raising your PH up to 7.2
    Jun 2013
    23
    The first weekend I started, I tested every hour and added bleach accordingly. I work during the week so I am only able to do it in the mornings and evenings. I've been vacuuming to waste and for some reason it is blowing it all back in the pool. I can't figure out why...
    Jul 2011
    Eastern Ohio
    7,086
    I'll let somebody else comment on the filter issue. No idea about sand filters.
    Jul 2011
    Eastern Ohio
    7,086
    Just did a bit of reading, are you 100% sure it's sand? Could it be dead baquagoo still hanging around some? Sand falls almost right away from the return..... Does the particles make it far in your pool???
    Jun 2013
    23
    They don't make it far and there are big piles here and there in the pool. I put a sock over the return to try and catch it the last time I vacuumed and it was sand along with some other nasty, smelly stuff.
    30,419
    When you vacuum to waste, the pool water goes through the multiport and out the backwash.....it never gets in the filter so you should see nothing returning to your pool nor be able to feel any flow back to your pool.
  20. Back To Top    #20
    Jun 2013
    23
    That's exactly what I thought. Nothing comes out for the first few minutes. Then when I hit a pile of nasty stuff it goes out the side of the pump but then starts blowing into the pool. I replaced the sand because it wasn't back washing like it should. The pool store said to try and replace the sand. It still didn't really work. Last year it would blow out of the side. This year it barely runs out. It's like something is clogged or something is wrong with the pump. I'm not sure, but it's frustrating.
