Thread: Pentair SAM with water in housing
    Water got in housing and bulbs went out.
    I took it apart and cleaned it up and put new bulbs in.
    Bulbs are not working. What would would be damaged from the water that would prevent the light from from working. Is there a repair kit for the electrical part of the light. I dont need a new color wheel motor. I just need the bulbs to work.
    All connections are good and no breakers tripped.
    Thanks
    14,500 gal pool
    Inground
    Intellichlor Salt Generator
    Water Fall
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Pentair SAM with water in housing
    Do you have a transformer for the light and if so, have you checked it?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    I dont have a transformer I have a Intellitouch
    14,500 gal pool
    Inground
    Water Fall
