Thread: Intex Salt Water Generator and Chlorine Free Shock?
    First year with an 18' above ground Intex Ultra Frame. I filled it with well water, and when I shocked it, it turned brown. Metal Out fixed the issue, but I haven't put chlorine back in it since, other than the floating tablet, so the chlorine level is very low or non existent. If I use chlorine free shock, will that still turn it brown due to the iron in my well water? I'd like to get the chlorine back to where it should be so I can then hook up the SWG, but will chlorine free shock work with the SWG?
    Intex Ultra Frame 18'x48"
    Intex 14-Inch Krystal Clear Sand Filter Pump
    Intex Intex Krystal Clear Salt System (not yet installed)
    Re: Intex Salt Water Generator and Chlorine Free Shock?
    Chlorine free shock is less effective and more expensive.
    It sounds like you have iron in the water. You will need to use Metal Out, or some other sequestrant, regularly as indicated on the packaging, but otherwise you should be fine to add chlorine normally.
    porkandbeans's Avatar
    Jun 2013
    SoCal
    42
    Maybe I'm wrong, but if you have put salt in why don't you just start the SWG and start making its own chlorine?
    5,061 gallon Intex Ultra Frame 16x48 Saltwater Krystal Clear
    Softub 280
    Quote Originally Posted by porkandbeans
    I was told the salt water maintains the chlorine levels but doesn't actually produce chlorine. Supposed to start it after the chlorine levels are where they should be. Am I wrong?
    Jun 2013
    SoCal
    42
    Quote Originally Posted by ylomnstr
    I am a novice, but this is what I did using my municipal tap water.
    Filled the new pool
    Checked and corrected TA and ph as needed (chlorine was at nothing)
    Added 120 lbs of salt (for 5k gallons I should have used 125 lbs, but oh well for now)
    Cycled the filter pump only for 24 hours
    Rechecked ph (good) and chlorine still at nothing
    Started SWG system running for 6 hours
    The next 3 days, both ph and chlorine are at healthy levels
    The electro-chemical reaction of the SWG system is designed to create, maintain, and replenish chlorine.
    Softub 280
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    The SWG does create chlorine but it works best at maintaining levels and if there is anything organic in the water it may not ever get to the cl level you need to maintain. It's easier to get to the correct level with bleach and then have the SWG maintain it. The water should measure .5 for CC or lower or you need to shock first.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
