Results 1 to 9 of 9
Thread: New pool...wait to swim?
    I read on here that you shouldnt swim in your new pool for 3 weeks but it looks like everyone fills them up and jumps in! Whats the scoop?
    Oklahoma
    30X20 Gunite pool completed in July 2013
    Yukon Jack's Avatar
    May 2011
    Rose Hill, KS
    94
    Re: New pool...wait to swim?
    If it has enough water to float my floatie,I'm in! Three weeks???? That's an eternity!
    18x33 AGP, 17,300 gal, Hayward Sand Filter, 1.5 HP 2 Speed Hayward Pump
    22,551
    You should follow the builders recommendation if it's a brand new pool. They're the one that controls the warranty and you don't want to do anything to void the warranty.
    Feb 2011
    Petaluma, Ca
    665
    I think it also has to do with what surface your pool has, with our pebble tech the builder said we could go in as soon as it's full, I think plaster is more finicky. Three weeks seems excessive to me but maybe he knows best. If you got in and out without touching the bottom what could happen.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    38,305
    I think part of the concern is that with plaster there can end up being a lot of clouding and stuff suspended in the water as the surface is brushed down. Or it could be the method of startup ... could be very acidic or highly alkaline.
    For a vinyl, fiberglass, or maybe even pebble pool ... once it is filled ... jump on in!!!
    30,421
    +1 what jblizzle said. Hard to hold back but your PB has a better grasp of his start up than those of us here.
    I might make a phone call to him for clarification....he might say it's OK to go a little earlier.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Listen to your PB of course. In my case he didn't really say much. But I knew they were doing an acid bath with the pool full so once the pH had risen to within range and chlorine was correct, we were in. It did take me a few days to realize that even a lot of chlorine disappears like magic in the sun with no CYA. I just was carefull not to brush right before we went swimming. It ended up being about a week after the pump was turned on that we swam. Good thing was it was cool out anyway and then, bam, at the one week point we had a few 90+ days which was fantastic for the first swim. Our finish is plaster colored gray with a little DB quartz.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Our pool builder hasnt said anything yet...Hope the pool will be done 2-3 weeks
    Oklahoma
    Feb 2011
    Petaluma, Ca
    665
    If you have your tf 100 you will know what the water chemistry is better that the builder in my opinion, my pool came with "a really good kit" according to them but in reality no good compared to the tf100.
