- Jun 20, 2013
- 2
Hello,
I am opening a pool for a family friend that has not been open for two years. The pool is 35' by 18' and shallow is 3' deep is 6'. Which I estimate to be roughly 21000 gallons. the shell is plaster and about 25 yesrs old with no visible signs of dammage to the shell. It only has about 1' or less of water in the deep end. From what I can tell the pool has two skimmers and one main drain. I see a sand filter with 1hp pump on it and a booster pump in the setup as well. There is a gas heater in the setup and a tablet chlorinator.
As far as I know the pool was winterized at the close of the last season that it was used. There is some grout the is deteorated around the tile row around the top of the pool. There is some debris cleanup necessary in the pool itself. The 1hp pump needs replacing, which I believe is the reason the pool has not been open in so long.
I am looking for advice for what to do first. Thanks so much in advance for any advice you guys may have.
