Thread: newbie needs assistance
    this is my first in ground poolso I'm very new to this. my concern is only one of my two return jets blows a little bit of bubbles, i know that means i have an air leak but why would it show in only one and does it matter that they're different sizes any help would be appreciated
    22,553
    Re: newbie needs assistance
    It's probably the closest or highest hydraulicly to the pump, and all the bubbles go there before they get to the others.
    that makes sense thank you. a couple other things, i have an in line chlorinator it's installed after the filter but it's three feet off the ground is it ok to reposition it lower? and other than a leak down is there any other means of testing for leaks
    22,553
    My personal position is that you should position the tablet feeder in a land fill... Just kidding!
    You can place it lower but it really won't make any difference in the performance.
    You can run water from a hose over the suspected parts and fittings of the plumbing while the pump is running and see if the bubbles in the pump basket lessen or go away.
