Thread: Balance even though H20 is green?
    Jun 2011
    Ontario, Canada
    20
    Hi All,
    I know the water has to be in balance before any attempt at the shocking process; however, should I be brushing/cleaning/vacuuming as well as running the pump and backwashing before adding any chemicals to the water?
    I've taken out all the leaves/debris, just stuck on this next step.
    Thanks.
    24k gal (100k L) inground vinyl|Watermaid EZY SWG|Hayward 1/2 hp & sand filter
    22,553
    Re: Balance even though H20 is green?
    Yes you should.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    It is best if the CYA is 30ppm and the pH is 7.2-7.5 before beginning the shock process. You should brush the pool, vacuum as needed and keep the pump running 24/7 throughout the shock process. Read through shocking your pool and defeating algae if you need to review the shock process before you start.
    Love TFP? Become a
    TFP Supporter!
    Jun 2011
    Ontario, Canada
    20
    Just to clarify: I should spend a couple days cleaning manually before testing my water and adding anything?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Quote Originally Posted by saysomething
    You won't be able to get rid of the green by filtering or scooping. But everything you can remove manually will reduce the amount of bleach and the time it takes to clear the water.
    My advice:
    Get the pump and filter running.
    Use a leaf rake - that's a special kind of mesh bag that fits on the pole - and drag out as much debris as you can. Brush the walls.
    After and hour of dragging and brushing and pool circulating, test the water. It will be well-mixed by then.
    If CYA is too high, now's the time to drain, and vacuuming to waste would be my suggestion for how to do it. If CH is astronomical, the same thing applies.
    Adjust the pH and measure out whatever CYA you might need to add to get to about 30.
    When pH is right and CYA is on its way to being right, hit it with bleach. Continue pulling out leaves, vacuuming, and brushing. Keep replenishing bleach.
    Don't bother testing anything but FC and CC until it's clear. It's easy to fine tune the levels once the water is clear.
    Plenty of detailed instructions can be found in Pool School or in the Algae forum.
    Jun 2011
    Ontario, Canada
    20
    Thanks, everyone, for your input. I just need to stock up on beverages, and I'll be good to go this weekend.
