Thread: New Pebbletec startup procedure
    Jan 2013
    Houston, TX
    1,079
    Gents,
    A friend is in the process of having a pebbletec pool installed and he hasnt talked startup with his builder. Whats the best route here? Traditional? Bicarb?
    Pool is in Houston...
    As always thanks in advance.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Re: New Pebbletec startup procedure
    A bicarb startup is best for the plaster, but should only be done if the builder/plaster people are on board. Because of warranty issues, you can make suggestions, but should go along with what the builder is doing. The best plan is to have a conversation about this with the builder in advance and make sure you know what they are taking care of and what is your responsibility.
