Results 1 to 7 of 7
Thread: 2650 Sand Filter
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    576
    2650 Sand Filter
    I purchased this last week and it is still in the box while I get my pool cleaned and releveled out. The plug on the outside of my house is no longer working so I will be replacing that.
    The housing unit that covered the receptacle (with the weather proof lid) would not fit the plug that came with the normal filter for the pool (cartridge 1,000gph pump). I had to remove the cover to get it to work. I know NOW that was retarded and lost 3 pumps and a receptacle that way... lessons learned
    I have the receptacle so I can replace it but I was just curious about the weather proof covers/box to go around it. I am not sure how big (or if I can even get one that is large enough) I would need to fit the plug for the new filter.
    Does anyone know how large the plug is (dimension wise) for this sand filter? Thanks!
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    22,550
    Re: 2650 Sand Filter
    I don't know how big it is but I know you can buy some really oversized weatherproof covers for outside receptacles.
    Jun 2013
    Cerritos, CA
    576
    I am having trouble finding any I will keep looking - just don't want to mess up like I did before *sigh*
    Christina
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You are looking for a "weatherproof in use" receptacle cover. I've found the plastic ones don't last. I use these around my farm.
    Jun 2013
    Cerritos, CA
    576
    Do you think this would be large enough?
    INTERMATIC Weatherproof Cover, Die Cast, 1 Gang, Gray
    Weatherproof Cover, In-Use, Receptacle Type Duplex/GFCI/Round, Horizontal Mounting Orientation, Self-Closing Lid Style, Number of Gangs 1, Material of Construction Die Cast, Color Gray, Height (In.) 4.50, Width (In.) 5.75, Depth (In.) 3.25, Standards UL & CSA, Includes Installation Hardware, Sealing Gaskets, 3 Inserts
    Says it is 4.5in in height and 5.75in deep... I hate feeling stupid
    Christina
    22,550
    I can't say without knowing what size and shape the plug end actually is, but that's a pretty big cover.
    Jun 2013
    Cerritos, CA
    576
    Thanks for your help - I appreciate it I just remembering a flurry of cuss words flying when I tried to plug the last one in lol
    Christina
