Thread: Thanks and a tip.
    May 2008
    Southern Virginia
    Thanks and a tip.
    Just wanted to say thanks for all the great information here. I had never owned a pool before but recently purchased a home with a 24' AG which I was very apprehensive about. The pool was a dark dark green, the pump was seized and the shed was filled with Baquacil products which after some research I decided I would switch to chlorine. After replacing the pump I adjusted the TA which was 48 and then shocked it hard with some trichlor powder that my neighbor had because I thought it would help in bringing up the CYA. Anyhow I then started adding the bleach and within 48 hours the green was all gone and the pool was a bluish white. I continued the bleach therapy for a few days and it just stayed the bluish white. I kept reading other posts on this forum that it would eventually clear up and then I could change my sand in the filter and start to enjoy the pool. I started to get impatient after a few more days and decided that if the pool and pump were in such disrepair that maybe I should at least check the sand in the filter. The sand was solid like plaster and there was a huge cavity that went straight to the bottom! No wonder the pool wasn't clearing. I changed the sand and cleaned the laterals and now the pool is at TA 110, PH 7.0, FC 16, CC 1.0, CYA 45 and CH 100. I plan to change the sand again and replace the laterals once the water clears and I can vacuum the bottom.
    My tip is this: If you inherit a poorly neglected pool, might want to check the sand in the filter along with everything else before starting. I sure most people know this but it never occurred to me.
    In conclusion I just want to say thanks to everyone who posts here and for all the great information on this site. I love the layout and the stickies, very informative and helpful.
    24' Round AG 13,000 Gal
    Hayward Sand Filter
    Southern Virginia
    Butterfly's Avatar
    South Carolina
    Hey Munch,
    Great first post!
    Welcome to the forum
    You're done SLAMing when:
    Mar 2008
    Central VA
    Welcome neighbor! And good info. in the post!
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    welcome to TFP!
    8000 gallon 20' x 48" round vinyl frame pool, 12" sand filter (don't have the specs on the pump), TF100 test kit
    Handy Links: PoolMath, TF-100 Test Kit, Pool School, CYA-Chlorine Chart
