Thread: never seen this happen before???????
    Apr 2012
    SW Ohio
    456
    I went over to my brother in laws today to test his water with my trusty test kit in hand his pool had some dirt run in it from the heavy rains the other night, he uses 3 inch pucks but he shocked it with 8 gallons of liquid shock 2 nights ago per pool store it is a vinyl lined 20x40 inground and new liner installed 4 years ago and has been using pucks ever since, and I was testing his t/a and the sample turned a light blue when I added reagent r-0008 and then I started adding reagent r-0009 drop by drop swirling the whole time at one point it started to turn red and then it went back to blue and then to yellow and stayed yellow for 25 drops and then I ran out of r-0009......why yellow?? bleach out?
    fc 38.5
    cc 0
    ph 7.6
    t/a ?????
    ch 250
    cya 140
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    38,305
    Re: never seen this happen before???????
    extended-test-kit-directions-t25081.html#p206395
    It goes from blue to yellow when the FC is high. You may want to try adding extra R-0007 as suggested in the link above.
    Apr 2012
    SW Ohio
    456
    so it is bleaching it out?
    that's what I thought anyways.....lol
    thank you jblizzle
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by fast1971chevelle
    Sort of -- it's half-bleached. The Total Alkalinity (TA) indicator dye in R-0008 is a combination of Bromocresol green and Methyl red dyes. At high pH above 4.5 the Bromocresol green is blue while the Methyl red is yellow so the combination looks green. At low pH below 4.5 the Bromocresol green is yellow and the Methyl red is red so the combination looks red (or red-orange if you keep adding extra acid drops in the test). High levels of chlorine will oxidize the Methyl red so that it is no longer colored so all you are left with is the Bromocresol green that goes from blue to yellow as you go from pH above 4.5 to below 4.5.
