Thread: Need to lower pH?
    May 2013
    South Florida
    55
    Need to lower pH?
    15K gallon pool
    SWG
    My levels:
    FC 5.5
    TA 70
    CH 250
    pH 7.8
    So, I guess I need to lower the pH huh? Maybe add 1 cup of muriatic acid (31.65%)? I added two cups yesterday. My pH was at 8.0 and dropped to probably 7.6, but now it's at 7.8. (I should mention I have problems with the pH color chart...they're all so close).
    I couldn't test CYA because the sun isn't out. I find it difficult to do that dot test.
    15K gal, IG plaster, screened, Marathon Electric 1 HP single speed pump, Hayward c-900 cartridge, Hayward SwimPure 40K SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,042
    Re: Need to lower pH?
    Unless you've been using pucks or powder to chlorinate, draining or backwashing, CYA should stay pretty much the same week-to-week.
    Let http://www.poolcalculator.com/ do the math for you. It will tell you how many ounces of acid to add. Target 7.4 and be done with it.
