Results 1 to 14 of 14
Thread: sand filter sand
    Jun 2013
    China Spring, Tx
    6
    sand filter sand
    I just bought a SF20110 intex sand filter. it says in instructions to use No. 20 silica sand or glass sand with particle size range of 0.45-0.85. question is where do i get this sand? will play sand work? Thank you, you guys have an awesome site here
    16' Intex ultra frame, Intex sand pump 2650 gph, installed 6-5-2013, SWG, Hayward skimmer
    38,290
    Re: sand filter sand
    Do NOT use play sand. Buy actual filter sand ... I think I have read that it is available at the large hardware stores. Or just go to a pool store, they are good for some things.
    Jun 2013
    China Spring, Tx
    6
    hahahaaa!! yes i know, was trying to save a dollar, plus the pool store is a little out of my way. Thank you for the reply
    Rumbum's Avatar
    Jun 2013
    Charleston, SC
    5
    don't worry, sand is still cheap at the pool store!!
    6.3K gal , AG vinyl 20' x 48" Intex Ultra Frame, .95 HP 2650GPH Intex 56671EG Sand Filter, 2011 Install
    Jun 2013
    China Spring, Tx
    6
    it was, 25 for 100 pounds. at lowes it is 8 for 100 pounds. hahhaaa thanks guys. great site.
    I just installed a new sand filter, and i bought Zeolite sand , which is supposed to be much better than regular sand...
    over twice the filtration level in microns , needs less back washing , and weight half...
    cant say how are the results and dont have anything to compare to, but at least on paper, it should be good.
    i think i paid about $20+ for the bag of Zeolite (25lbs which replaces 50lbs of regular sand)
    Oct 2012
    Houston, TX
    186
    Last year (my first year with a sand filter) I considered Zeolite but I couldn't find consistent or conclusive reviews. There were many brilliant as well as awful reviews and being a newbie I decided to skip it. For jollies I even asked my local Leslie pool supply guy about it, and even though it was more expensive he wasn't pushing it. He basically shrugged and didn't try to sway me either way.
    This year I have a chance to re-think it because I'm not setting up for a few more weeks. Anyone have any comments about it?
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    any reason you are completely replacing your pool every year ???
    Jul 2009
    S. California
    157
    Quote Originally Posted by hyperionguy
    For jollies I even asked my local Leslie pool supply guy about it...
    That makes me smile because my local Leslie's guys are so ignorant. On my last visit the guy (kid really) didn't know what a gasket or a PVC bushing was
    Caveat Emptor
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    We get large numbers of reports of problems with zeo media. When it works it seems to work great, but it can occasionally cause serious problems, so we do not recommend using it. Besides, few people can tell the difference in water quality between zeo and sand.
    Jul 2009
    Houston, Tx
    19
    Quote Originally Posted by talhart
    Seems to be upgrading each year.
    John
    Intex 22 x 52 Ultra frame, 10,400 gals
    Intex 2600 gl/hr sand filter
    I got 50lb bags at True Value for $7.
    1) 7500 Gallon Free Form Gunite Pool / 800 Gallon Gunite Spa
    2) EasyTouch 8 Automation / IC20 Intellichlor
    3) Intelliflo VS Pump for pool and water features - Cartridge and DE Filter / 2 Speed Pentair Pump for Spa and Cartridge Filter
    Oct 2012
    Houston, TX
    186
    Quote Originally Posted by Livinright
    That was the goal!
    Cool, thanks for the input... your opinion is enough to tip me to again buy regular pool sand.
    Quote Originally Posted by gd5015
    John
    That's right!
    I enjoyed the year 1 pool so much that I wanted something bigger and the year 2 pool is nearly double the capacity.
    During year 2 I decided the pool visually dominated the yard. I can't tell you how many people came over and said "Jeebus! wth?". I think what contributed to the illusion is the more severe slope of the sides on the larger easy-set and the blow up ring crown on top. I started having dreams of something more 'normal' and better filtration, etc. I ran across a good deal on my first ultra-frame and went for something smaller. The problem is... I live in a patio home so my yard space is limited and even where I could fit a long narrow in-ground pool (I like that look) there are utilities underneath, so it would be cheaper to just move than to fix all that. The back yard is split in two by concrete pad and steps out the back sliding doors, right in the middle of the house. The side I put the 15' easy-set on probably had only 6 feet left on 3 sides. My side yard is a better shape but has a good slope to it and has too many trees.
    During year 3 I was the happiest I have been with an AG pool (I grew up with an in-ground pool) mostly because I learned a lot from you guys and it became nearly maintenance-free other than vacuuming. It was fun. Also, my theory was validated... that a smaller ultra-frame would actually have more usable space and feel more open than an easy-set. The idea is that even with a smaller overall diameter I would still have more surface area as well as not wasting all that volume beneath the sloped sides. I hadn't noticed as much on the smaller easy-set model but when I went double-sized the slope was much bigger and wasted a lot of space. I think that's also what made the big easy-set look so bad in a small space, it just looked so much like a big sack o' water.
    I had fun trying out new things like adding the bigger Intex return that came with the sand/swg filter and adding the Hayward skimmer. Based on how the pool looked, I decided I could go back to a slightly bigger pool without it looking like the sack. I wasn't seriously considering it until I accidentally stumbled across the 14' x 42" on seasonal clearance at Wal-Mart (online only!) for under $200.
    I tried giving away the smaller ultra-frame, including posting here to find someone who knew someone local who would take it for free... including leaving in the bigger return and thru-wall skimmer. No takers. So I took off the parts and pitched it. A waste, I know.
    This year I'm going to hard-plumb the new ultra-frame and since I'm in the middle of reworking the back yard before installing the pool, I plan to keep it up year round since I don't have to winterize in Houston. This may be the one I stick with for good.
    I already have two H-D bags full of PVC parts I'm collecting as I mentally sketch out the plumbing plans. I can't wait.
    JamesT's Avatar
    Jun 2013
    Little Rock, Arkansas
    48
    A 50# bag at Ace hardware runs about $9.00 Not all the stores have it in stock but they can get it pretty quick. Its and HTH product and I called the HTH help line. It is #20 silica and graded at 0.45. The store where I got mine said he had 200 bags...guess he is planning to sel a bunch. I used it in my new Intex filter and no sand grains ended up in the pool.
    8 year old Intex 16 x 48 metal frame - Intex 1600 Pump with 14" sand filter - Intex Old Style SWG (ladder broke and poked huge hole in the side)
    New 18 x 48 Ultra frame Intex - Intex 2650 pump with sand filter - Intex Old Style SWG
