Thread: Pool Heater By-Pass?
    Hi to all;
    Pool heater has by-pass installed, just wondering if there is any reason to keep it in the loop when not in use for the rest of the summer. Should I drain and blow out excess water.
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    Re: Pool Heater By-Pass?
    Bypassing the heater when you won't be using it for a while is easy and well worth. Draining the heater until fall is more work and makes less difference. There is no harm in it, but I doubt it will make a detectable difference.
