Results 1 to 10 of 10
Thread: lstewaMN
    lstewaMN
    Just opened a new 20' diameter INTEX pool. Had water delivered due to high metals in our city water. Just trying to learn what I need to do to manage the water chemistry. I love this site so far but am a bit overwhelmed at all the information here.
    8.5K gal, AG, Krystal Clear Sand 14" model #SF15110; flow rate 1600 gal/hr, June 2013
    38,521
    Re: lstewaMN
    Welcome to TFP!!!
    Best way to start learning is through reading Pool School (button at the upper right of the page).
    Have you order one of the Recommended Test Kits yet? That is the key to understanding and maintaining your pool.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: lstewaMN
    Since you have a real need to "keep that water you bought" focus on getting your FC (Chlorine) levels correct and then work on your other levels (ph, TA, CYA). The green monster is what you want to avoid and CL will keep it away. Bleach/chlorine is your friend. If you have water, you need bleach.
    While it sounds extravagant, the recommended test kit will save you tons of time and money in the long wrong... and toms of heart ache in the short and long runs. It really does cost less than most trips to the pool store.
    -- Guy --
    Re: lstewaMN
    I did buy the test kit from Taylor that was recommended. It came today. TA was super high 210, but PH was 6.8' FC was 8.5 and CYA was below 20 meaning the dot never went away just got a bit cloudy. Just trying to read a bit more to see what to do next to adjust the PH without raising the TA even more.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: lstewaMN
    Sounds like you making good progress and learning the ropes.
    -- Guy --
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: lstewaMN
    Welcome to TFP!
    I would suggest reading all Pool School articles, but would start with these: ABC's of Pool Water Chemistry, Basic Pool Care Schedule, Recommended Pool Chemicals, How to Chlorinate Your Pool, Chlorine CYA Chart, The Shock Process. This will give you a good baseline and make the remaining articles easier to understand.
    Re: lstewaMN
    Thanks. Looks like aerating is what I need to lower the TA without continuing to lower the PH. Sadly my free aerators (AKA my kids) refuse to get into the pool yet and splash! Still a little too cold since the water was delivered at quite a chilly temp.
    38,521
    Re: lstewaMN
    To be clear, aerating does not lower the TA, it raises the pH ... which then allows you to add more acid to lower both.
    Re: lstewaMN
    Thank you for the clarification. We just got a lot of rain last night so I'll test again today and see how to proceed.
    Casey's Avatar
    SW PA
    10,457
    Re: lstewaMN
    Welcome to TFP! Enjoy Pool School!
