Thread: Help Please
    Help Please
    Hi there!
    We've had our pool in ground pool since 2005 and I am going to be taking over the maintanence of it since my hubby has strange hours and we've been having issues for the last year....
    Our pool has a southern exposure and is usually about 87 degrees... we have a solar system on our homes roof and we usually cool the water at night.
    We've been having trouble with cloudy water and keeping the FC going (although I think the pool smells like chlorine) In the past we've had trouble with 'dead chlorine' but the pool company doesn't say that's an issue now. About 2 weeks ago the pool clouded up and we took a sample in and then did what was recommended... 2 days later it's happening again only it seems to have a tinge of yellow.
    Pool tests say the following: CYA not accurate due to other levels
    Tot Chlorine 3.3
    Free Chlorine 0
    pH 7.9
    total Alk. and adj are both 140
    total hardness
    filter was cleaned on 6/4/13
    Where do you suggest I start? How do I equate liquid bleach to what is recommended by the pool company? Should I drain some water out and start over?
    Any help is greatly appreciated... had planned a pool day.. weather is great and we had to cancel... AGAIN!
    haven't made a sig yet...
    built IG, pebble tech pool in 2005
    14,300 gallons with a sand filter and solar paneled heating
    we have a southern exposure ... we have swim jets and fountains
    let me know if I have forgotten anything
    mrsstanps.... a momma who wants to swim with her little chicks!!!!
    Jul 2011
    St. Paul, MN
    244
    Re: Help Please
    Start by purchasing one of the two recommended test kits http://www.troublefreepool.com/pool-...kit_comparison.
    Then read pool school http://www.troublefreepool.com/categ...etting_started.
    You will need to complete the shock process on your pool as described in pool school. But, until you have your test kit and can test your CYA level, that will be difficult to do.
    Until your test kit arrives, you could add about a gallon of bleach a day and also lower your pH to 7.2.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Re: Help Please
    thank you! they are recommending 60 lbs of shock and then bring back a water sample.... my mouth dropped!
    We had started to drain some water out so we can replenish with fresh water.... we are draining down to the bench level (2nd step) and then will add fresh water... (the water won't be like bath water either!!!)
    hubby will fill in all the missing parts on the pool and equipment.
    thanks,
    mrsstanps
    Jul 2011
    St. Paul, MN
    244
    Re: Help Please
    Did they give you a reason why you should drain some water?
    I wouldn't do anything except the following until you get your test kit:
    - Add 1 to 2 gallons of bleach a day
    - Add acid to lower pH to 7.2-7.4 range. Use www.poolcalculator.com to figure out how much acid to add.
    - Keep your pump running 24/7. Clean filter as needed to keep a strong flow out of the returns.
    - Read and reread pool school so that you understand your pool chemistry, the effects of adding different chemicals to your pool, and learn how to complete the shock process on your pool.
    It is quite possible that you will need to add the equivalent of 60 lbs. of powdered chlorine, but you will want to use liquid chlorine or bleach instead. But, until you receive your test kit and are able to do your own testing, you won't know for sure.
    Clearing up your pool may be a long process (i.e. days to weeks). But, if you follow the advice of the experts here on the forum (vs. the pool store), you will be happy with the end result.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Help Please
    Quote Originally Posted by mrsstanps
    I saw you use solar at night, but you can also cool your pool with something like this ... my-version-of-a-pool-cooler-operating-off-a-return-t48856.html
    Search the forum for pool coolers and you'll see lots of other ideas
    Welcome!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    38,526
    Re: Help Please
    Welcome to TFP!!!
    I too am not seeing why you should be replacing water ... although you did not report the CYA or the CH levels which are really the only reasons to need to replace water if they get too high.
    faby has given you good advice ... the recommended test kits are the best investment you can make and will certainly pay for itself after the trip you DO NOT make to the pool store.
    Likely you will need to go through the Shocking Your Pool PROCESS when your kit arrives.
