Results 1 to 8 of 8
Thread: Pool Pilot Nano Salt Chlorine Gen - Not generating chlorine
    Any ideas on this?
    No warning messages on Pool Pilot display (indicates 73%), but water check reads chlorine level at 0.
    Pool water looks just fine.
    Did some troubleshooting, tested and found voltage too low (1 V), but amperage is OK (5 Amps).
    Tech says unit voltage should be between 17 & 19.
    Thanks!
    Ft Lauderdale, Florida
    1,455
    Re: Pool Pilot Nano Salt Chlorine Gen - Not generating chlor
    Put the unit in boost mode first, let it run a minute, then run the test mode.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Welcome to TFP!
    The odds are fairly high that your problem is incorrect chemical balance, and the SWG is working just fine. If you would post a complete set of water test results we can probably figure out what is happening.
    Did try the boost suggestion, no change
    Here is complete set of readings:
    Chl 0
    PH 7.4
    TA 80
    CH 300
    Cyn 70
    Salt 3800
    1,455
    It may be possible for the internal fuse to blow that may cause low volts.
    Your numbers are fairly good, no immediate indication of problems there. Plus, the boost test indicates the problem is with your SWG, not the chemistry.
    While you continue to have problems with the SWG, you need to remember to add chlorine manually. You don't want to leave the pool without chlorine for long or you will get algae.
    1,455
    how old is your Nano?
    The is 2yrs-9mos
