Results 1 to 9 of 9
Thread: Removing Hayward Offline Chlorinator - plugging holes
    May 2013
    Erie, PA
    53
    Hi,
    I have a hayward offline chlorinator hooked up which I havent used for 2 years. The only reason I even have it hooked up is because of the two holes I had to drill in my pvc piping to install it.
    Does anyone know what I can use to cap these holes off so I dont have to hook it up anymore? Trying to avoid having to redo my pvc.
    Thanks!
    22,700 gallon, 18x36 Vinyl IG - Hayward EC65 Perflex DE Filter
    22,553
    Re: Removing Hayward Offline Chlorinator - plugging holes
    Some people just take one tube and run ti between the holes in a loop. It bypasses a little water but not enough to matter.
    You could always just thread them and screw plugs in them. That's what I would do.
    macgyverMOM's Avatar
    Jun 2013
    Indianapolis, IN
    1
    I took those two plastic "washers", filled them with PVC glue, (dug thru my scrap screw box until I found the perfect size) and placed a screw just covering the hole. Made sure the screw end went into the PVC side (i was afraid if i didn't the screw would come flying at me). I let it dry for a few days and installed normally with the clamps it came with. Three weeks and still holding!
    18,300 gal, OLD Jacuzzi Laser Sand Filter, IG Vinyl, All equ. 10 years old +
    May 2013
    Erie, PA
    53
    Great! Thanks for the suggestions!
    I had tried running one tube between the two holes (though without the loop). That worked out alright but I wasn't sure if it was also causing DE leak into the pool.
    Thanks again!
    Apr 2014
    United States
    21
    Can some one help me out with "Made sure the screw end went into the PVC side". Here are the steps I understand:
    1. Remove the chlorinator tube. Fill up the the plastic washers where the pipe went into with pvc glue
    2. Do you place a screw into the two washers or into the pvc pipe below the washers?
    Jul 2014
    Westport, CT
    65
    I have the same problem with a leaking chlorinator that is no longer used. I stopped by home depot and they don't have any PVC caps in this size, but they did have brass caps that fit.
    Is this a bad idea given that brass will corrode with bleach over time?
    48,000 IG Gunite - Pool built 1999
    Hayward DE-6000 Filter w/ C-1100-SEP Separation Tank
    Hayward Super Pump 2.0-HP : SP1615Z1MEG
    Hayward H-Series heater
    TF-100 Test Kit
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Drill them out to 3/8', tap them, install pressure gauges. Then you can tell at any time what your differential is for filter cleaning intervals.
    Factory Warranty Station for:
    Jul 2014
    Peoria, IL
    389
    Why not just cut the pipe out and replace the whole piece? I know you said you did not really want to but it is the most fail safe method.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Jul 2014
    Westport, CT
    65
    This thread is a very old one, that I piggybacked off of, but @bdex, personally, I was keeping mine in the event that I invest in a Liquidator. I would try and utilize the same fittings that are already there and working fine.
    TF-100 Test Kit
