Results 1 to 7 of 7
Thread: New to pool chemistry! Need some help
    Hello all....I live in the northeast and have had my gunite pool for 3 seasons... I have a intellichlor salt generator and was told it was maintenance free...well reading these boards I have come to find out it is not true....I took the advice and invested in a Taylor chem kit....I have been having issues with a small amount of algae growth around the pool swim out in the grout lines...so I have tested my water and here are the results.
    Pool temp is 70 degrees
    Roughly 18000 gallons.
    I have the intellichlor set to 100% output
    My pool also has a spa that attached to the pool and overflows
    Cya test: basically this test revealed extremely low cya as the black dot never disappeared upon testing so it less than 30
    Ph: 7.9
    TA: 140 ppm
    Free chlorine; 7.4 ppm
    Calcium hardness: 250 ppm
    How does it make sense that my cya is so low yet my free chlorine is so high....what are my next steps to balancing this water? Please help! Thanks so much
    22,548
    Re: New to pool chemistry! Need some help
    What size cell on the swg do you have?
    The first step is to lower the pH and then get some CYA in there.
    I have an IC40 cell
    Let me know what I should get cuz after I get some help here I will go to the pool store to get chemicals....any suggestions? Should I use the supplied calculator?
    22,548
    You should use the Pool Calc to figure the doses. I'd shoot for about 50 ppm CYA.
    An IC-40 cell on a 18,000 gallon pool running at 100%? There's no wonder that the FC is so high.
    I'm extremely po'd at the pool company for never telling me about adding stabilizer all the said was to change the output....what % out put would you suggest once stabilized....
    This board is great btw...I'm learning tons!
    22,548
    The percentage is going to depend on the FC level, but I'd start at about 50% and test and adjust from there.
