Results 1 to 15 of 15
Thread: Is it possible to have TOO MUCH GPH Sand Filter?
    Hello Again,
    I have a couple more days of leveling left for our 15x48 intex. Upon your advice, Im going with the Krysatl Clear SWS. My wife just picked up the 14" Intex 1600 GPH sand filter. I just noticed a sale on the Intex 2650 GPH sand filter, with a price differance of only about $20. Do you guys think I should upgrade to the big guy, or is it just too much on my 15x48? (Which I think is approx 4400 gallons.) Thanks again!
    Just upgraded from Intex 15x48 to Pro Series 22x54
    2500gph Intex sand filter
    Intex Krystal Clear Saltwater System
    Located in Boston, MA
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: Is it possible to have TOO MUCH GPH Sand Filter?
    i ordered the 2650 sandfilter for our new 18 x 48. (6423 gallons) IMHO, you cant have too much circulation / filtration. at any rate, a bigger pump / sand filter means you run it less which should save you some $$$.
    if you already have the 1600 though, im sure it will be more than adequate.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Thanks for the reply. The wife just got the 1600, but we are still in the process of the build, so plenty of time to return it. For $20 more, Im also thinking longrun if i decide to upgrade next year to a bigger pool.
    30,426
    Absolutely get the 2650. You'll never look back, even on your existing pool.
    For $20 more I'd exchange it for the bigger one, but that said I have the 1600 on my 15' pool and it works great, and it seems like a lot of people use them on 18' pools with great results.
    Summer Escapes 15'x42" AGP, Intex 14" sand filter, Intex SWG
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    It is in no way too big at all. My first pool was an Intex 12 foot round. Pump was garbage, and I knew I'd be getting a bigger pool in a few years when the children were a little bigger. I bought the 2650 sand filter and put it on that pool!! Not too big at all. Return the 1600 and get the 2650 for the extra 20 bucks!!
    Edited to add:
    That being said, the 1600 will do you fine if you don't want to return it. When I bought mine the 2650 was a 16 inch sand filter and the 1600 was a 14 inch. Can anyone tell me if it's the same? If the 2650 is still 16 inch it would also mean that you would be backwashing a little less often.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Wow, you guys are great! Thanks for all the advice. 2650 it is!
    Jul 2011
    844
    You're here only a couple of weeks and already you have seen the benefit of this forum!! Best on the net!!
    I see you're in Boston, and I'm a Habs fan. Had I noticed that earlier I would not have offered any helpful advice!!
    Bestway SWG
    LOL, glad the B's did not have to face you guys post season this year!
    Thanks again for your help-
    Jul 2011
    844
    No problem. If the Bruins win tonight (which I think they will) then the cup is theirs. Chicago won't win 3 straight.
    Bestway SWG
    Jul 2009
    S. California
    157
    I would get the 2650 as well.
    The 1600 is working fine on my 18', but more circulation and a stronger vacuum would be alot of bang for $20.
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    Jul 2011
    844
    Quote Originally Posted by Livinright
    Exactly. What you are getting for 20 bucks is stronger circulation, faster turnover, stronger vacuum, and less backwashing (which means adding water - which means CYA levels change, salt levels change if a salt pool, and a % change in all your chemicals). For 20 bucks, it's a heck of a bargain.
    Edit to add: Anthony, your Bruins won last night. I'm not to happy bout that!
    Bestway SWG
    May 2012
    Baltimore, Maryland
    183
    I just installed the intex 2650 sand filter to my pool last weekend. Def something I should have done sooner. My pool is a 15x4 round intex. The sand filter came with the larger valves aswell as the adapters for the smaller connections. I installed with the adapters just to make sure the unit worked. After I confirmed it worked I cut the holes for the larger valves. everything I already have for the pool works with the pump. I did however need to drill holes in my screw on vacuum attach because it caused the new style twist plunger valve to open its safety suction release and allowed air to enter the system.
    I run my pump on timer 4hrs in the am and 4hrs in pm.
    Much better compared to 24hrs with the origional 1000gph pump
    And I dont have to clean the filter every other day anymore
    15'x4' Metal Frame Intex 3yo (2nd year winterized) 16" 2650gph intex sand filter, Thru wall skimmer, dual inlet/single outlet, 1000gph intex pump (heater) Solar Cover TF-100 testkit, TFPC
    Jul 2009
    S. California
    157
    Quote Originally Posted by mrmacdad12
    I just installed the intex 2650 sand filter...I run my pump on timer 4hrs in the am and 4hrs in pm.
    Wow man, that is some serious filtration! 8 hours per day on that filter will turn your pool over about 5 times every day. Your water must be amazing.
    7100 gallons
    TF-100 test kit
    May 2012
    Baltimore, Maryland
    183
    Its day and night compared to the 1000gph cartridge filter. I check my pool twice a day, 7am and between 6-7pm, the intex filter only has settings for 2,4,6,8,10,12 hrs. I just find it easier to flip the timer switch to 2 and back to 4 which kicks the pump on. 2 hrs isnt enough in my opinion 4 might seem like overkill but it works for me. the pump is only .95hr/6amps so about 660watts/hr. not to bad. Im def a happy camper so far wish I would have upgraded sooner...
