Results 1 to 20 of 20
Thread: How often do you pull critters out of your pool?
    Jan 2013
    The Great State of Texas
    243
    I am usually not the squeamish type of woman, but as of late I am about ready to claim helplessness and go shoe shopping. How often do you pull animals from your pool? In the last month aside from a crazy amount of huge bugs and spiders, I have pulled out countless frogs - 2 of them dead in the skimmer. I have pulled out 11 snakes, all quite alive, some of them I am sure are repeat offenders. One day I had 3 in the pool at once! And I have pulled out 3 DEAD moles (I think they are moles. They have fur and it makes me too sad to study them much). Of course I shock the crud out of the pool every time someone decides to off themselves here.
    If I get anything bigger than the moles that are furry and dead I may not make it. It is rainy here for this time of year, so I fear it is only going to get worse as the drought season kicks in. Other than maybe a St. Patrick statue to drive off the snakes ( ) any thoughts on anything else I can do. Granted, I want the moles gone, but really didn't want them offing themselves in the pool. Tell me this will pass.
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    25 year old pool w a facelift in 2014
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: How often do you pull critters out of your pool?
    If you think they are coming to the pool looking for water you can try setting out a big, shallow tub of fresh water away from the pool to see if that helps.
    Love TFP? Become a
    TFP Supporter!
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by glitter&guns
    Talk about timing ...... i just took my cover off and saw a big item in the shallow end ..... from a distance it looked like a small piece of firewood.
    Closer inspection revealed a dead squirrel
    I don't want to hijack your thread but the answer to my question will fit right in so i will ask it .... I assume the only thing i need to do is get a little extra chlorine in and let it work?
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Jan 2013
    243
    [quote=ship of fools]
    Quote Originally Posted by "glitter&guns":1x6kqcle
    I don't want to hijack your thread but the answer to my question will fit right in so i will ask it .... I assume the only thing i need to do is get a little extra chlorine in and let it work?[/quote:1x6kqcle]
    I assure you that I am no expert on this at all, but I have just been raising the chlorine level to "kill a plague" level and keeping everyone out for a while. I cannot possibly drain the water every time a critter dies in here (although that is my gut instinct - drain it, and run pure bleach through every part of everything for 3 days, then start over - obviously not necessary, but ICK!!!!!!).
    Sadly I don't think mine are getting in looking for water as some of these mornings there has been standing water from rain coming through.
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    Nov 2011
    Albany, NY
    495
    I'm not all that worried about it .....i swim in lakes on a regular basis and i am guessing there are a few dead critters at the bottom
    Plus i always run my chlorine just a bit above the low end of the recommended levels.
    Haywood Sand Filter
    Vinyl Liner
    Jul 2009
    Houston, Texas
    9,409
    Quote Originally Posted by "glitter&guns":25tbf1s9
    I don't want to hijack your thread but the answer to my question will fit right in so i will ask it .... I assume the only thing i need to do is get a little extra chlorine in and let it work?[/quote:25tbf1s9]
    As long as the deceased is intact and not oozing any bodily contents and your FC is at the top of your daily target you should be ok. If you want a little insurance bump the FC to shock level and do an overnight test. If your FC was below the daily level or the deceased was not intact go ahead and raise the FC to shock level and do the overnight test. Remove as much of the deceased from the pool as possible.
    The thing about lakes and streams is that there is a much larger volume of water so the dead critter to water volume ratio is much higher that it would be in your pool. There is also a constant exchange of water going on in lakes and streams that is mimicked by the filters we use on our pools, except most of us don't run our pump and filter 24/7.
    Love TFP? Become a
    TFP Supporter!
    Nov 2011
    Albany, NY
    495
    Thanks
    The other thing i forgot to mention is my pool temp is only 70 and no one has been in for two weeks and i highly doubt anyone will be in for a few more days.
    Gotta love the great Northeast
    Haywood Sand Filter
    Vinyl Liner
    Apr 2013
    Central Massachusetts
    174
    The critter was alive when it fell in your pool so it shouldn't have been teeming with bacteria like a decomposing animal. And since your pool was sanitized to begin with, there shouldn't be much decomposition going on in the pool either. I wouldn't be to worried and certainly wouldn't consider draining the pool over it.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    Jan 2013
    243
    Quote Originally Posted by MassNerd
    This is completely the logical answer to the whole thing and I completely understand what you are saying. And I believe this on a scientific level. On a "OMG there is a dead thing in my pool" level, draining and bleaching everything feels so right. I am going to force the logical side of me to win out, but I am oh so tired of having this fight with myself.
    On a side note, I am sure I am over reacting with the amount of bleach/filtration/abandoning the pool that I am doing, but maybe as I get used to the idea of swimming in dead mole water I will have an easier time. Or maybe the dang things could just quit drowning in my pool.
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    Jan 2013
    243
    [quote=zea3]
    Quote Originally Posted by ship of fools
    Quote Originally Posted by "glitter&guns":1xlxtbv0
    The thing about lakes and streams is that there is a much larger volume of water so the dead critter to water volume ratio is much higher that it would be in your pool. There is also a constant exchange of water going on in lakes and streams that is mimicked by the filters we use on our pools, except most of us don't run our pump and filter 24/7.[/quote:1xlxtbv0]
    Great point about intact vs "way dead" animal. Thankfully mine were all newly deceased.
    I have also done a lot of water skiing in my day, but always figured that lakes were kind of "self leveling ecosystems" unless something really bad is going on with them. I do avoid lakes during times of "turn over" due to the chance of higher fish kill off (probably not necessary, but again, sometimes the idea wins out over the fact), but figure the rest of the time in most lakes everything is kind of a happy little ecosystem.
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
    Never -- one of the few perks to having an AGP w/o decking.
    Pulling them from the dog's mouth is a different story.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    I have to remove rabbits, often in pairs, way more often than I'd like, which is NEVER! I am a female that doesn't want to deal with dead critters but my husband is disabled and isn't wheeling out there to do it for me. I suit up with tons of plastic gloves & bags, and I use a grabber tool, also covered in plastic. I double, triple, quadruple bag the stuff--ick! We live in a pretty cityish suburb, but we have rabbits everywhere (no dispute over where the multiplying jokes come from).
    12k gal IG, rectangular, plaster, Hayward pump, Hayward cartridge filter Model c4025, Kreepy Krauly. No trees, no shade, all day strong sunlight. House was a foreclosure, bought 10 years ago, no paperwork or documents about the pool
    Jun 2013
    SpringHill FL
    415
    I cant count the number of live chipmunks anmoles ive rescued from drowning in my pool or the number of drowned ones ive had to flip off my paddle skimmer into the woods. But i am confident of the sanitary conditions of the pool so i dont give water quality a sec thought
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    wmorge's Avatar
    Jun 2013
    Terre Haute, Indiana
    81
    I've only killed a few frogs.. thankfully but what I do dish out every couple of days is those rolly polly bugs. I empty out at least a cup of those insects out of my canister vac every couple of days.. I suppose I will count my blessing. I haven't dealt with snakes.. eek!
    16x32 I.G. Vinyl, Hayward Pro High-Rate Sand S220T, Vari-Flo XL Valve, Hayward Super Pump 1Hp , Great White cleaner, Hayward W530 Leaf Canister, TF100, Pool Skim.
    Jul 2007
    NW FL
    25
    I used to have to pull large toads out of the pool all the time. Sometimes I'd get to them before they'd drown and sometimes not. I got a Frog Log and it really helped. My old one finally wore out so I ordered a new one last spring, but I haven't really felt the need to put it out yet. I'm only getting the occasional tree frog during rainy weather. I have two new, young indoor/outdoor cats who love to hunt and I think they are keeping all the critters scared out of our yard!
    23K gal., kidney IG vinyl, 3/4 HP pump, sand filter, Baracuda G2
    Jun 2012
    Butler, PA
    336
    growing up with an IGP we had:
    Deer: several times, twice destroying the liner
    Bats in the skimmer box
    Opossums/Groundhogs/ Raccoons
    Snakes/ Salamanders
    Toads/Frogs
    mice/moles
    neighbors blind dog ~ she would cross the road and take a swim several times a season
    litter of St. Bernard Puppies all walked right in like baby ducklings ~ our dogs the majority of them all enjoyed the pool
    I am sure I have forgotten critters ~ but they were pretty much a daily even for us.
    Have an AGP now:
    so it's just been bugs and one cat so anxious to get in and swim she can taste it but she doesn't have the courage to take the plunge. She has no problem getting in the bathtub though & I have to lock her out if I run a sink full of water in the kitchen.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    mmn's Avatar
    Jul 2013
    South Florida
    34
    My problem is not dead things but what live ones leave behind. Once in a while there's raccoon poop on the steps in the morning. Can't seem to figure out a suitable deterrent.
    Regards
    Michael
    14,288 gal IG freeform Diamondbrite
    Hayward 9002 filter
    3/4 hp Hayward pump
    Barracuda G3 cleaner
    TF-100 test kit
    resurfaced 6/2013
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What timing, I know someone that has spent nearly the last year or so having initial start up problems with theirs second pool (builder / automation systems, etc). They just got things all lined out a few weeks ago and were finally able to start using their pool, then last week an escaped cow decided to cool off in their pool. I swear that house is cursed, nice big 5,000+ sq ft house on about 10 acres about 5-10 miles out of town, screened small lap pool, and now outdoor sport / general use pool, was on its 3rd owner before construction was complete, driveway paved, etc.
    Jun 2012
    Butler, PA
    336
    We had friends who moved down south (years ago, I was a teenager) ~ and they had an armadillo that visited frequently & he would float around if it could get on a pool float. He truly seemed to enjoy a daily swim.
    We never had a cow ~ that would have freaked me out
    For deterrent we were always told to go to a hair salon & get hair clippings and put them in nylons and hang them around pool and garden ~ human scent is supposed to keep most away. Kind of a tossup in the gross factor ~ critters floating or unknown hair clippings flapping in the breeze Now the people who went with that method made decorative socks and hung their clippings so it wasn't as nasty as it sounded, but still not real appetizing to be having a dog and drink by the pool thinking about those hairs... We didn't go that route. We did plant plenty of marigolds and that did help, but wasn't total resolve.
    Full Sun ~ All Day
  20. Back To Top    #20
    Jan 2013
    243
    OK... cows and deer?!?! I will stop complaining about the moles. Maybe it is the stupid heat, but I haven't had a mole or a snake in a week!!! Gobs of pill bugs (rolly polly bugs) and grasshoppers, but for whatever reason I have less problem with dead bugs than dead furry things.
    Thanks for making me feel better about it all!
    ~18,000 gallon
    DE filter/chlorine
    IG Grey Plaster
