Results 1 to 7 of 7
Thread: Can't Remove Elbow Assembly/ Check Valve
    May 2013
    Erie, PA
    53
    Hi,
    I have a hayward EC65 and I'm trying to get to the check valve inside the filter. I'm guessing that I need to remove the elbow assembly, but it's stuck in there pretty good. Any ideas on how to take it out? I don't want break anything.
    I attached a photo of the part I'm referring to. If you cant see the photo, I believe the part number is "ECX4220A Elbow Assembly w/Check Valve"
    Thanks in advance.
    [attachment=0:4n5k6pga]elbow-assembly.jpg[/attachment:4n5k6pga]
    22,700 gallon, 18x36 Vinyl IG - Hayward EC65 Perflex DE Filter
    22,542
    Re: Can't Remove Elbow Assembly/ Check Valve
    The middle tab has to be pressed toward the elbow side. Have you tried that? try using a flat blade screwdriver to wedge it over with.
    May 2013
    Erie, PA
    53
    Hi Bama Rambler,
    Thanks for the reply.
    Yes, I did press the tab in. It's just stuck in there pretty good. Anyway to pry it up without breaking?
    22,542
    I'd slip a flat screwdriver against the tab to hold it over and then just wiggle it as much as you can to get it loose.
    May 2013
    Erie, PA
    53
    Ok, I'll try that.
    Am I correct though that the check valve is in that part? I'm just going by the part diagram fro the manual.
    Also, If I cant get the part out, is it alright to just leave it be. The reason I wanted to remove it is because sometimes when I backwash the filter DE is coming up the main drain. I have the filter running 24/7 so I dont ever see it come up the main drain any other time (though i'm also currently tackling de on the pool floor by the return jets - which is why the filter is all apart!).
    I hate to not have it done right, but I also dont want to break anything else!
    22,542
    If you can't get it out and you don't want to take a chance on breaking it, just leave it alone.
    what type backwash valve do you have?
    May 2013
    Erie, PA
    53
    I just have a ball valve on the drain outlet at the bottom of the filter. No multiport or anything like that.
