Results 1 to 17 of 17
Thread: Think my pump is too big, but would like others opinion/help
    I purchased a 1hp Hayward Power-Flo LX Series for my 22'x4' AGP last summer. I thought our current pump setup (2 intex pumps running side by side) was toast, but it turned out to be debris trapped in the intake of the first pump. So the new pump was never installed. This summer I decided to install it and sell my other pumps as one went with a small intex sand filter and a friend wanted it. I am using an old 200lb sand filter my dad had that is rated for 44 GPM max and my pump shows 60 GPM, I never really thought this would be a problem. But I am now having issues with my pump blowing fine sand/dirty water through my filter, it isn't the filter sand it is fine sand from the pool. If I vacuum a spot that is really dirty I can see it come right out my return. Is there anything I can do besides buy a new smaller pump or larger sand filter to resolve my problem.
    Thanks
    Tanner
    22' x 4' Intex Ultra Frame 11,000 gal, setup in summer of 2012. Hayward Power-Flo Lx 1hp 60GPM pump, Pentair SD 80 sand filter, wide mouth skimmer, all hard plumbed
    38,279
    Re: Think my pump is too big, but would like others opinion/
    Did you thoroughly inspect the filter before installing it? No problems with any of the internal parts? Did you check the backwash valve seals to make sure you are not just bypassing the filter?
    Do you have a valve on the pressure side that you could partly close to increase headloss and reduce the flow rate to see if that really is the problem?
    I took the sand out and filter internals out today and checked everything internally and all was good. Not really sure about the backwash seals not really sure how to check them. The seals that I could see inside the valve looked to be in good shape. I am getting really dirty water out on a backwash and I rinse for at least 1 minute. I do have a valve on the pressure side, so your saying to choke it down some and see if it stops. I had thought of that but have not tried it, wasn't sure how much to choke it down.
    38,279
    As long as water keeps moving, you will not hurt the pump. You could try choking it down some and vacuuming and see if dirt still returns to the pool.
    What is the diameter of your filter?
    Jul 2008
    Flintstone, GA USA
    112
    I would guess by your posting that your spider gasket or seal in your sand filter valve is bad. If so
    this will allow some of the filtered out matter to go back into your return line instead of going through the filter or to waste whichever setting you have choses.
    I have a Hayward S200 sand filter and know that I have had to replace this spider seal 2 times in 40 years. If they are not glued down properly with waterproof adhesive they will eventually fail.
    You have to take the top off your 6 way Hayward valve that is attached to your filter. This applies if you have the same Hayward filter that I do S 200.
    Tom
    18 x 36 Grecian Polynesian Fiberglass Walls with Concrete bottom - 3 ft to 9 1/2 ft. deep -
    Hayward Variable Speed Super Pump SP2600VS 1 1/2 True HP,Hayward sand filter S200, and Hayward auto clorinator. Hayward 250,000 natural gas heater. PoolKeeper automatic water leveler. Loop Loc Ultra Solid Safety Cover. Hayward Color Logic 12 volt light. Dual Pool Deck Jets.
    Polaris 380 auto cleaner. Trouble Free Test Kit TF-100.
    30,419
    Assuming you are backwashing correctly, your filter should not be returning dirt to the pool. I would inspect the sand bed to see if it is reasonably clean and not channeled. As suggested above, throttling down the pump is an option as well.
    Well I thought I had this figured out choked the pump down and it seemed to work but pool was fairly clean. We have had sand storms all week and pool has been super dirty today tried to vacuum with valve still choked down and sand starting coming back into pool. Tried to choke it down some more and still sand coming through..very very fine sand so fine that it makes the water look murky and you cant see the actual sand particles and it takes several hours for it to settle on bottom.
    Today I took valve apart to inspect spider gasket, it looks ok no visible rips or uneven wear, but it is worn down some. Only problem is all the stickers on the valve are all gone and the only sticker on the filter itself says Auquatools, and I can't seem to find any info on them. The diameter of the filter is 20", the sticker on the side of the filter that shows specs is somewhat intact so I can get a pic or info off of it, but it is against the fence and its dark so I will have to get the info tomorrow as I will have to spin filter around and it's still full of sand and water.
    One thing is I did notice inside the pipe going to the later tubes the water was dirty just like the water coming out of the filter so make me think it has to be coming from the filter side and not the valve, but I could be wrong.
    Here are some pictures of my gasket, what do you guys think? I found a source for the plug and gasket assembly, and a new spring for about $40, I am guessing I should probably replace those and see what happens.
    38,279
    Nothing looks obviously wrong with the gasket to me.
    I didn't think so either I have seen bad gaskets (was a GM technician for 13 years) and this one looked ok to me. But then again I have never seen a new gasket to compare it to. I really think my filter is just to small and I am blowing the fine particles through it. Pump is 60GPM and filter is rated for 40GPM. One question though, typicaly how far from the top of the filter opening should the sand be? I am thinking maybe I need to add some sand mine is about 12" below the top of the neck opening.
    mas985's Avatar
    Pleasanton, CA
    11,737
    How do you know the pump is producing 60 GPM? Do you have a flow meter?
    Mark
    Quote Originally Posted by mas985
    Just going by the ratings on the pump. I assumed it would be atleast that, I have 2" plumbing and not a very long runs.
    Here are the specs for my pump..
    Voltage
    115
    Port Size
    1 1/2"
    Cord Size
    6'
    Ctn. Qty.
    1
    Ctn. Weight
    25 lbs.
    H.P.
    1
    40 ft
    58 GPM
    50 ft
    27 GPM
    10 ft
    86 GPM
    20 ft
    86 GPM
    30 ft
    75 GPM
    mas985's Avatar
    Pleasanton, CA
    11,737
    What is the filter pressure and the gauge height relative to the water level?
    Mark
    10 psi when clean the water level is 46" gauge is 34"
    THink I am just going to break down and order a new/bigger filter. Would this work ok for with pump? http://www.amazon.com/Pentair-145322.../dp/B002C0GNRU
    mas985's Avatar
    Pleasanton, CA
    11,737
    The pump flow rate is over 60 GPM and closer to 70 GPM so you might consider the SD 80 instead just to be safe. Plus Pentair overrates their filters so technically, the SD 80 is more like a 70 GPM filter than a 80 GPM filter.
    Mark
    Ok replaced filter with new Pentair SD 80 and 350lbs of new sand and STILL having problems. I think I am using the wrong sand, I have been using the Quikrete Pool filter sand from Home Depot and I think its sand particles are too big. I finally found on the company's website (not on the bag) where it is .85-425mm and #20 is like .45-.55mm. Not sure why it worked fine last year besides the fact my old pump wasn't pushing water through it as hard. Frustrated, but hope this solves the problem.
