Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Salt Water pool help
    We have a salt water pool and have had problems two years now. The chlorine level is reading high, ph is fine and salt reading is at 2800. I have noticed a lake smell from the skimmer basket. Are there any really good test kits that anyone would recommend. We replaced the salt generator last year so I know it is working. Everything seems fine but I do not think the pool is at optimal conditions. The bottom of the pool is slippery like we are getting some form of algae but you cannot see anything. Any advice would be appreciated. Thanks JB
    26k Gal, IG Vinyl, Hayward Sand Filter #S244T, 1HP Hayward Pump, Aqualine SWG, built 8/2008, Oklahoma
    Re: Salt Water pool help
    tftestkits.net Get the TF-100 with xl option and salt test strips. Best money ever saved!!!
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    Welcome to TFP
    Yep
    Get the TF-100
    Easy to use and works great
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    You have a lot to learn. You say your chlorine is high and your PH is fine. What exactly does that tell anyone here? You say your salt is 2800 but do not say what salt generator you own. You neglect to mention any other parameters regarding your water chemistry such as CYA or CH. Please read pool school several times over. Get a good test kit and post your results for quick end efficient help. Test kit help is available at
    pool-school/pool_test_kit_comparison.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by ComputerGuyInNOLA
    I'm sure your didn't mean it to be, but at face value this sounds pretty un-welcoming. It would to me anyway.
    To the OP, sorry for repeating, but in order to help you, but we really need some solid numbers to help you out. The only way to know is to test properly and getting a good kit is paramount. It will be one of the best investments you will make for your pool. The Taylor K-2006 or the TF-100 are the best drop test kits money can buy, but we all like the 100 because there are more of the exact same reagents in that one. Up to you, but without those numbers it will be impossible to give you the correct advice. Based on your description, it does sound like you may be lacking in free chlorine level.
    Welcome to TFP, and do check out Pool School.
    Essential Links:
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Read Pool School, the link is upper right corner.
    Ok now have the TF100 test kit. Results are as follows:
    FC-14
    CC-0
    TAK- 90
    Calcium - 220
    CYA - 30
    PH- 7.5 to 7.8
    Chlorine level with other test kit is off the chart
    SWG is reading 2600 now and the add salt light is on. This is my firs time to own a pool and I need some help and advice on where to start.
    May 2013
    Deep East Texas
    79
    Looks like you are at SLAM level. Shocking is a good way of getting rid of slippery surfaces. Don't forget to brush.
    In ground 25,000 gallon - vinyl liner - Sand filter - residential pool
    Also maintain two commercial 190,000 gallon competitive indoor bromine facilities -9x Sand filters
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by jbryant15
    FC-14
    CC-0
    TAK- 90
    Calcium - 220
    CYA - 30
    PH- 7.5 to 7.8
    Hey, good deal! Glad you got a good kit. The best actually, and your numbers look pretty good for now except your CYA. With a SWG you really need it to be higher. A level of 70-80 is higher than for non salt pools, but you need the extra protection when running one. What source of Chlorine are you using to get to 14 PPM FC? Are you going through a SLAM (Shock Level and Maintain Process) ? Let us know and we can go from here.
    Essential Links:
    My kids are complaining about the chlorine level hurting their eyes. Actually have not done anything yet. We added a couple of bags of salt about a month ago. Other than that we have not done anything else. The salt water generator is showing 2600 which it should be around 3400. But won't that increase the free chlorine level. I really need to get the chlorine level down. The pool guy has not been very much help last year so I have not called him this year. Where do we start this process?
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    The salt level should be within the range recommended by the SWCG manufacturer. As long as you are in the range, the actual salt level will not affect the chlorine level. What brand SWCG do you have? The chlorine level is usually set by a knob on the controller marked in %. If you have too much chlorine, just reduce the % some. The other factor that affects the amount of chlorine the generator makes is pump run time. How long do you run the pump a day?
    You should really look at the info in the pool school section. Lots of good info plus guidelines on how to get the most from the forum. The folks who run this board have invested lots of time in helping pool owners solve their problems. Take a quick look at the two links below as a sample.
    Mike
    http://www.troublefreepool.com/pool-...ater_generator
    http://www.troublefreepool.com/pool-...efore_you_post
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    Mike_W's Avatar
    Aug 2011
    142
    Well - talk about great minds... Looks like you added a sig line with some good info while I was (very slowly) typing away. What model Aqualine do you have?
    Mike
    We have an aquarite electronic chlorine generator. Not sure what model#. I checked the unit and manual but could not tell the model#. I went ahead and turned the dial down to 30%. It was at 60%. The pump runs constantly. No one has ever told us to turn the pump off. Since the free chlorine is at 14PPM and the CYA is at 30. Which one do you attack first. The FC should be around 1-5 I do believe and the CYA should be around 70-80. Everything else looks within normal ranges.
    22,545
    Well at least you know there's nothing wrong with the swg or the water.
    Here's what I would do.
    1. Turn the swg off until the FC gets to about 5 ppm then turn it back on at about 20% and monitor the FC level and fine tune it.
    2. Add enough CYA to get to about 70 ppm.
    3. Cut down the pump run time unless it's a 2-speed pump running on low. Even then I'd probably run it 12 or so hours a day.
    4. Retest pH and adjust it to about 7.5 or so.
    Go swim!
    do you think we need to add salt since the SWG is reading 2600 or just wait? The PH is between 7.5-7.8 so I think we are fine there. Thanks for your help. JB
    22,545
    I would add enough to get to the mfg's recommended range.
    The pH is probably fine but any time the FC is higher than 10 ppm we don't trust the pH reading so just check it again when the FC comes down.
    Thanks. I will try this. Thanks
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You got great advice. I'll add this just incase...you don't have to buy "Pool Salt" at the pool store, as hardware, grocery stores and Walmarts usually have solar salt for softeners. Walmart also has "Pool Salt" in that section too, but it's a dollar or more so per bag. Just avoid the stuff that says resin cleaning, or iron cleaning for softener resin.
    Essential Links:
    what is the best stabilizer to raise the CYA?
  20. Back To Top    #20
    Mike_W's Avatar
    Aug 2011
    142
    I buy mine at Home Depot, where it is sold as "Pool Time Chlorine Stabilizer". Any brand will do as long as it is 100% cyanuric acid. Just be sure to read the pool school article on how to added it.
    Mike
    http://www.troublefreepool.com/pool-...pool_chemicals
