Results 1 to 15 of 15
Thread: muriatic acid
    muriatic acid
    I need to lower my TA and we bought the muriatic acid at the hardware store. The type we bought is Crown NEXT which is supposed to be a safer form of it, with less fumes. Is it a problem to use this form or should I get the normal muriatic acid?
    Gia1975
    27' above ground
    17,100 gallons
    sand filter
    38,235
    Re: muriatic acid
    Welcome to TFP!!!
    Depends what makes it "safer". Usually it just means that it is a lower concentration of acid {that they charge the same amount of money for}
    What is the % listed? Any other interesting info on the package?
    Re: muriatic acid
    Thanks for the welcome! I have learned much since I found the site last August. Then I needed to raise my alkalinity and instead of $80 worth of the pool store's buckets I used $8 worth of baking soda
    The label says "Crown Muriatic Acid NEXT is the safer alternative to Hydrochloric Acid 20 (however you make that degree symbol on here) Baume (31.45%) with less fumes and lower odor." Nowhere does it say what the actual concentration is. It just compares it to the 31.45% concentration.
    Ahhhh. I just tracked down the company's site and you are right. It's a 9.8 (degree) Baume 14.5% solution. And, of course, according to the pool calculator I'll need twice as much of it.
    Thank you.
    Gia1975
    27' above ground
    17,100 gallons
    sand filter
    38,235
    Re: muriatic acid
    You got it
    Jul 2014
    BH (Saratoga Area), NY
    62
    Re: muriatic acid
    I was just about to ask about this. At Lowes now comparing the two. The Crown regular version says "do not mix with chlorine type bleaches or any other household product, exterior use only" Im assuming this is the right stuff though as its straight MA, right? Any info on the percentage for this one?
    Jun 2012
    Jackson, NJ
    105
    Re: muriatic acid
    I just went through this and since I needed like 7 gallons I was comparing the regular crown and the NEXT, good thing I got the regular 31.45% as others have said only difference is lower concentration.
    I/G Concrete w/spa 29k Gallons (I think lol)
    DE
    Nature2 thingy disabled
    Polaris 280
    Aqualink RS4
    Jul 2014
    62
    Re: muriatic acid
    Lowes has the Crown brand: Reg (unkown percentage) is $6.49/gallon; Next is $7.29/gallon (15% I think we concluded)
    Ace has the 31.45% for $7.99/gallon
    Quote Originally Posted by AdrenalinPlease View Post
    How did you find out the percentage on the Regular? I couldn't find it anywhere
    Upstate, NY, Direct Sunlight, Above Ground (18'x 33' x 4'), Oval 15700 gallons, Vinyl; Hayward S180T sand filter; 1 HP motor; TF-100
    Jun 2013
    East TN
    309
    Re: muriatic acid
    Bought some MA from Lowes about 2 weeks ago. Im pretty sure it was the NEXT brand. It did say on the back but it was kind of hard to find. It was 31.45%. There was also a brand that said Safer, but I didnt bother to even look at it because it should have been half strength.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: muriatic acid
    Quote Originally Posted by Eddy24 View Post
    You would never want to directly mix muriatic acid and chlorine. However, you can add chlorine to your water with the pump running - wait 30 min - then add your acid. Or vice versa.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Jul 2014
    62
    Re: muriatic acid
    Quote Originally Posted by northrn View Post
    ah, gotcha. I can't remember if I waited or added to the pool closely together... hopefully it's not a big issue.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: muriatic acid
    Very true!
    I was in a hurry last time I needed both MA and chlorine and added one at the east return, then one at the west return. Figured it was OK in a 40' long pool. That was the same night I discovered high humidity and no wind = bad time to add MA from a large pitcher. In the headspace on the top of my measuring pitcher the acid fumes were mixing with the water vapor in the air, creating a much larger cloud of noxious gas than usual. No wind means it didn't go anywhere but linger over the pitcher and in my general vicinity. Think I'll stick to adding it directly from the bottle. Small opening = less opportunity for water vapor to mix with acid fumes. A few ounces off by eyeballing the measurement is not a big deal in a ~30K gallon pool.
    Isolated Spa - 345 Gallons
    Jun 2012
    Jackson, NJ
    105
    Re: muriatic acid
    It is on the bottle, I dont remember where exactly but its on there.
    Quote Originally Posted by easttn View Post
    The NEXT is the lower safer percentage.
    DE
    Polaris 280
    Aqualink RS4
    Mar 2013
    Southlake, TX
    114
    Re: muriatic acid
    I use the Crown product from Lowe's. It is 20 Baume = 31.45%
    19' x 37' Freeform IG; 25,500 gallons; max depth 8'6" with diving board; sun bench and swim out shelf. PebbleSheen Blue Granite Finish; Noble Tile--NVSA616 Peacock; Sandstone Retaining Wall; Oklahoma Flagstone Coping, Aggregate Deck; Small Water Feature w/ Moss Rock (70% flats and 30% boulders) Jandy Stealth 2HP Pump and CV460 Filter; AquaCal SQ156 Heat Pump/Chiller; Polaris 380 pressure cleaner w/ Halcyon boost pump.
    Mar 2013
    Southlake, TX
    114
    Re: muriatic acid
    The label has a QR Code (Quick Response Code). If you scan it you get this URL http://packserv.com/mobile/crown/cle...acid/index.htm
    That takes you to a product spec sheet/booklet. Hope this helps!
    Jun 2013
    East TN
    309
    Re: muriatic acid
    AdrenalinPlease was right. It was Crown I bought. It says the percentage on the back label up above where it says DANGER! POISON.
