Results 1 to 9 of 9
Thread: Turbo cell -HELP!!
    Turbo cell -HELP!!
    I am new to the site and am looking for help-I have a Goldline Turbo cell-salt generator(Tcell-15)and have a no flow error-the flow sensor seems to be part of the Turbo cell?How can I trouble shoot??Thanks for the help-
    38,371
    Re: Turbo cell -HELP!!
    Welcome to TFP!!!
    The flow sensor the the Goldline is NOT in the cell. It is a little black piece inserted on the middle of a Tee fitting. Check that wire to make sure it is not chewed up or cut.
    Wow-I thought that was a temp sensor and the white wire from the cell was the flow switch-The wire was cut(CHEWED) right off!!!I will resplice and give it a try in the morning-Cant thank you enough !!!!!-I finally feel I found a place to help with pool questions-wish my weekly service guy would have found it??
    38,371
    Sorry it took all of 2 minutes to answer your question
    I probably should replace the flow sensor with new wire-do you know where its best to get a replacement-Thanks again..
    mas985's Avatar
    Pleasanton, CA
    11,741
    It is basically phone wire and you can get that almost anywhere: Walmart, Home Depot, Lowes
    Mark
    OK-WILL GIVE IT A TRY-TKS
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    You can splice it with tiny wire nuts and then a good tape job...that's what I did when a rat chewed through mine.
    thanks-Ill try that for now-dont know why they like pool parts??
