Thread: Possible causes for DE leaking into pool
    May 2013
    Erie, PA
    53
    Hi,
    So I got my Hayward ec65 taking apart looking for what could be causing de leaking into the pool. Didn't see any tears in the fingers and everything looked good. What else could have caused the leak? Could the gasket have gotten unseated?
    Thanks in advance!
    22,700 gallon, 18x36 Vinyl IG - Hayward EC65 Perflex DE Filter
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Possible causes for DE leaking into pool
    Assuming you speak of the big o-ring on the body of the filter, it is on the "dirty" side of the filter, if its leaking, it will leak on the ground. I have not played with the head. I would be interested to hear what an expert says.
    -- Guy --
    May 2013
    Erie, PA
    53
    The diaphragm gasket that is around the nest of tubes/fingers.
    38,294
    Could be the gaskets in the backwash valve as well.
