Thread: Jack's Purple vs Walmart's hth metal control
    spiazza's Avatar
    Berkeley Heights, NJ
    76
    Has anyone tried using Walmart's HTH Metal Control as a cheaper sequestrant alternative to Jack's?
    I typically use Jack's Purple Stuff (Salt water). The cost ranges between $23 - $30.
    HTH is $12. Active ingredient: Hydroxyethylidene Diphosphonix Acid.
    My Pool Stats
    IG Pool - 21,000 Gallon - Vinyl Liner
    Hayward 1.5HP Super Pump EE; Hayward DE Filter; Goldline SWG
    32' x 16', 8' deep at the deep end, about 3' shallow end
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Jack's Purple vs Walmart's hth metal control
    Hmmmm..
    HTH 20-30% http://www.homedepot.com/catalog/pdfIma ... eec7cb.pdf
    Jack's Purple 100% http://www.jacksmagic.com/pdfs/MSDS-JMPURPLE.pdf
    Better check the dosing table. Sometimes the cheaper stuff works out to be more expensive.
    spiazza's Avatar
    76
    Those are the details I was looking for. Thank you
    My Pool Stats
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    I have been doing some experiments with iron staining by doing AA treatments, messing with pH and just started using Jack's (pink). I have been looking at alternatives due to the same reason....cost.
    I was pleasantly surprised to see that HTH Metal Control was HEDP based and was half the price. After looking over all the MSDSs carefully I discovered the following:
    • Jack's Pink________1qt./10,000____HEDP___Sp.Gr. 1.48
    • Jack's Blue________1qt./10,000 ___HEDP___ Sp.Gr. 1.09
    • Jack's Purple_______1qt./10,000___HEDP___Sp.Gr. 1.09-1.19
    • HTH Metal Control___1qt./10,000___HEDP___Sp.Gr. 1.46
    Only HTH/Arch Chemicals gives an actual percentage of the HEDP ~32%. The Jack's MSDSs give a percentage but it says 100 percent "Proprietary Formulation" which contains HEDP. It's not 100% HEDP. Who knows what other ingredients they add to make it more effective in certain types of pools or with different metals. All that said ...Jack's Pink and the HTH Metal Control look very similar. In the end, all that really matters is the active ingredient. I've read a few posts and it seems the HTH works. There are a lot of percentages being thrown around 60%, 30% and 20%. I guess all you can do is give it a shot and if it works then you are saving $$$ and your pool will be sparkly.
    toxicity-of-hedp-t56605.html#p464642
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
