Results 1 to 11 of 11
Thread: Brand New Pool owner with some questions
    forya's Avatar
    Jun 2013
    SE Pa (Bucks County)
    49
    I just bought a foreclosed house in the northern suburbs of Philadelphia, Pa. Either the previous owner, or bank drained the Viking Caribbean fiberglass pool and it heaved and split end to end. I choose to build a whole new plaster pool and deck, and it was filled 3 weeks ago. I have been brushing everyday (usually twice a day) and adding chlorine and muratic acid, as needed by the test strips the pool company gave me.
    They gave me chlorine tabs to add to the chlorinator, and they told me i could start to vacuum after 3 weeks. I have a lot of built up leaves from a giant nearby oak tree. Should I invest in a robot? The pool company did add a sweep line into the pool.
    Should i also be running my pomp at 75% 24-7?
    I ordered the TS-100 test kit.
    25,000 Gal, Plaster, IG, Auto CL, Waterfall, IntelFlo VS Pump, Dolphin DX6 Robot, TF 100 test kit, Merlin Safety Cover Lots of Trees!, South Eastern Pa
    30,421
    Re: Brand New Pool owner with some questions
    Welcome to the forum.
    . I think your best bet is to continue that routine for now. When your kit gets in, open it right up and perform the tests and post the results. We'll all help you get things in balance.
    Hold on the robot/cleaner for now. It's a decision that involves you getting to know your pool a bit better.
    NICE pool!
    Casey's Avatar
    SW PA
    10,448
    Great looking pool!!! Welcome to TFP!!!
    welcome... I'm new to the forum as well and I have to say these guys have help me out a ton. Also, I live in the suburbs of Philly as well in Bucks County. Let me know if you ever need any help.
    forya's Avatar
    Jun 2013
    49
    Thanks, It's tough to wait.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    You will learn P.O.P.P very quickly then. Pool Owner Patience and Persistence!
    Jun 2013
    Hartland, MI
    67
    This forum has made me an expert compared to my friends with pools. I have almost considered changing my line f work after three days of nonstop reading. It all seems a bit overwhelming, but once you get it right it's simple maintenance.
    24'x54'' AG
    Appox. 13800 gallons
    150lb Hayward sand filter
    1.5hp pump
    Well water
    Jun 2013
    Hartland, MI
    67
    This is what I started with.
    This is what I have now, a little vacuuming and I can start swimming. Patients is the key.
    24'x54'' AG
    1.5hp pump
    Well water
    forya's Avatar
    Jun 2013
    49
    How long do I have to wait to get a Cleaner?
    30,421
    Wait the three weeks the plasterer suggested. You can get one any time you like but I wouldn't put it in the pool before then.
    forya's Avatar
    Jun 2013
    49
    It has been 3 weeks yesterday. I was thinking about a robotic cleaner, so i can run it at night. Is that a good approach to keeping the floor and walls clean, or is it better to run while the pumps are on?
