Thread: 2-way valve on input to pump?
    Feb 2012
    Maryland
    400
    Is there any practical reason to want/need a 2-way on the suction side of the pump? Im just wondering if I will ever need to turn the water off for any reason at that point.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    38,305
    Re: 2-way valve on input to pump?
    The only reason would be if the pump was below water level and you would need to close it when you wanted to clean the pump basket. OR if you have multiple suction lines, you could either have a 2-way on each or a 3-way to select between the floor and the skimmer (Since this is new, I certainly hope you are running the floor and skimmer to the pad separately).
    You signature is not clear if it is an in-ground pool.
    Feb 2012
    Maryland
    400
    Yes, it is an inground and I ran a 2" from the main drain to the pad, a 2" from skimmer 2" to pad and 2" from skimmer 1.5" to pad as a backup. Pump will be slightly below level of water. I will have a 3-way connecting skimmer/main drain feeding into pump.
    I was thinking of taking the output from the 3-way, feeding it into a 2-way prior to entering pump.
    38,305
    I know the Pentair valve have a little pin you can pull that allow you to shut off the center port (so no 2-way would be needed because the 3-way could shut it down). But, I am not sure if the Jandy valves are as easy or if you have to cut off or modify the stops.
    Feb 2012
    Maryland
    400
    Hmmm, it is a hard plastic stop. I could file it down. I wonder though if that is more risky/hard than putting in a 2-way. I already have extra 2-ways.
