Thread: Conversion Started! Last night 8:30pm, FC Test question
    Jun 2013
    Portland, Or
    24
    I started my conversion last night at 8:30pm. I added the correct amount of 8.25% Bleach from the pool calculator. I waited an hour and a half then tested my FC with a Taylor 2006. This is where the questions start:
    1- When I first tested I had to add about 4 scoops of the powder into the 10ml test kit and it only turned a light shade of pink (not the dark shade I see on the testing videos). Then when I added the reagents It look over 30 drops and it would only stay clear for a second or two. So I called it good for the night.
    2-6:30 this morning I test for FC and I put 4 big scoops of the poweder into 10ml of pool water and nothing just clear water. Does that mean that I have no FC?
    Thanks in advance,
    The Sad Pool Boy
    12 x 24 Doughboy Above Ground Vinyl Liner With Deepend
    7740 gallons
    Pentair MiniMax 100 Heater
    Meteor 22.5 sand filter
    30,424
    Re: Conversion Started! Last night 8:30pm, FC Test question
    Yes, you have no FC. You should only use one scoop...... VERY VERY rarely two are required....never more.
    If you are going to convert, get your FC up to the correct level and keep it there with constant testing and replenishment.
    Jun 2013
    Portland, Or
    24
    Thanks for the help! Its funny how much you can read and read and think you have your bases covered.
    This is a great resource!
    7740 gallons
