Thread: Possible risks using SWG with AGP?
    We have a 24' round pool AGP - Sentinelle brand made by Aqua Leader. Purchased and installed two years ago. Now starting its third season in Maryland. All parts of the pool are resin with the exception of the main wall. We have an Aqua-Trol SWG that has was purchased about 6 weeks after the pool was installed, and it has worked very well for us.
    With the pool we purchased a 13' x 5' three segment, "fan tail" deck. The deck uses a lot of vinyl and resin, but the under-structure that supports the deck as well as several small braces that are used to stabilize the entire structure are painted steel. I just spent a very significant portion of this past weekend repairing the paint system on this deck. It was awful - huge chunks of paint would peel off. Most of these chips had rust and metal that peeled off with the paint. Rust stains had developed on the top rail of the pool where the deck had overhung the pool. I sure was disappointed to see such a massive paint system failure after only two seasons!
    Today I called the local pool store/supplier - punt. They are under duress - closing all their stores in Maryland and several other states. Their corporate headquarters basically said that after one year they can't help us. They referred me to the Canadian company that manufactured the deck. So that was my next call.
    The story from the deck builder was that they do not warranty any of their products that are used with pools that use a SWG. He went on to claim that the use of SWG was a ticking time bomb in the industry. He told me that I should carefully inspect the pool walls and especially the closure bars/seam that completes the wall system. He made it sound as if our continued use of a SWG with an above ground pool was putting my family and friends at risk. He even emailed me a copy of their current warranty page where they decline all responsibility for rusting if their products are used in pools "utilizing salt generation for water stability." Many of his comments were a disturbing - suggesting types of injuries and then describing sudden failures of major structural components of pools and of products that they make. In-pool ladders was one of his major concerns - claiming that the stainless steel fasteners they use will/could degrade and fail over time.
    So - is there any real hazard using a SWG with an AGP? Am I putting people and property at undo risk? Or is this just a scare tactic to encourage me to go away?
    24' x 54" Sentinelle AGP (New in April 2011) // 1.5 HP two-speed pump // 22" sand filter (150#) // Aqua Rite SWG
    22,551
    Re: Possible risks using SWG with AGP?
    Welcome to TFP.
    Seriously, think about who you were talking to! The guy that built the deck that's failing. What did you expect him to say? Of course it's not a problem with his deck painting system. (we need a sarcastic smily)
    By voiding the warranty on all swg pools they have just dumped a large portion of their responsibility. It saves them tons of money not having to repair failing systems. It's easy enough to design and coat systems to hold up in any environment that they may encounter. A pool with chlorine in it is pretty corrosive. Just water is pretty darn corrosive itself.
    I wouldn't worry much about his domesday scare tactic. There are thousands of steel walled pools that have had swg's for many years and they're not falling apart and killing people.
    Hire a Lawyer and have him send a letter , then contact your Better Business Bureau. If all this fails, contact your states Attorney General and perhaps they can help. Many companies do not want a tarnished reputation so if you squeak enough, you will get greased
    24' round AG 15K gals. DIY solar heater. SolarChlor Max producing free chlorine!!. Pool is crystal clear!! Doing my best to use natural products or processes.
    john redcorn's Avatar
    Jun 2013
    B.A. Okla.
    64
    Tell him you don't use "salt generation for water stability" you use chlorine generation (which may or may not involve store-bought salt that you didn't generate.) Ask him what he thinks a judge would think aboot the legality of that little line in his warranty disclaimer.
    18' Summer escapes with original skimmer + intex pump + intex sand filter w/ Zeolite, Intex SWG. 1x ecosaver 50sqft solar panel with dedicated pump.
