Results 1 to 14 of 14
Thread: CYA test with Taylor K-2006
    May 2013
    South Florida
    55
    I bought the Taylor K-2006 test kit and am loving it. Great kit!
    My only problem is with the CYA test. I have a **** of a time being certain of my accuracy with the CYA black dot test. Any tips out there? Should I be reading the CYA level once the black dot first completely disappears from view? In other words, when I am first not able to see it whatsoever.
    I have to say I hate the black dot. It leaves too much up to interpretation.
    15K gal, IG plaster, screened, Marathon Electric 1 HP single speed pump, Hayward c-900 cartridge, Hayward SwimPure 40K SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: CYA test with Taylor K-2006
    Take a reading, pour it back in the mixing bottle, shake it up, and try again.
    [center:28xjd0ez][youtube:28xjd0ez]NxaqoW-_MCs[/youtube:28xjd0ez][/center:28xjd0ez]
    May 2013
    Bay City, Michigan
    283
    Continue pouring until all traces of the black dot at the bottom of the view tube completely disappear, even after you stare at it for several seconds, or you fill the view tube.
    It does only go in increments of 10 so absolute accuracy isn't quite necessary.
    Quote Originally Posted by doglover78
    Any tips out there?
    I ended up doing it a little differently, looking from the side I fill the sample to the first line then go from above and look. Then keep filling to the next line until I go to look and don't see it. I found keeping my head over top of it was playing eye games and dealing with the reflection of my head was ******* me off.
    Don't know if that's good or bad, its just what I decided I liked doing better.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    22,551
    You could order some 50 ppm standard solution and test with it until you get your testing method perfected. I have it and used it so I could tell exactly what I was looking for.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    You'd think someone could come up with some sort of color changing test. Lighting seems to make a big difference! Make sure the sun isn't shining on the tube. I can make the dot disappear with sun at my back, but let a little sun in and it reappears and takes another "10" to disappear again. +/-10 is probably good enough, but be nice to get a +/-1 reading.
    IG pebble, 15,000 gallon
    48” PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    jgofnj's Avatar
    May 2013
    Hillsborough, NJ
    167
    What I find funny about the video is it says make sure the sun is to your back, but the guys is facing the sun while doing the test in the video.
    20,000 gal, In-Ground (built in 2007)
    Vinyl lining / 1HP Hayward SuperPump / Hayward Pro-Grid DE Filter / Hayward Gas Heater / Liquid Chlorine,Bleach (4 Gallon Liquidator)
    Dohney Discovery Robot
    Testing Method: TFTestkits/TF-100
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by jgofnj
    I noticed this too. Quite puzzling that the maker didn't mind that little detail.
    Essential Links:
    357's Avatar
    May 2013
    SE Michigan
    15
    Could someone make their own 50ppm test with distilled water and CYA granules so we could verify our testing methods? I know it's sold for $8.50, but many of us here have CYA and distilled water on hand. Even if we had to add 1/8 teaspoon to a 5 gal bucket, then use a dropper for the test, it would be way cheaper/faster than ordering the pre-made 50 ppm solution. Any chemistry wizards know how much granulated CYA would have to be added to a 1 gal carton of distilled water to get 50 ppm?
    18' round Intex Ultra-Frame pool, 48" deep. Default "A" size filter with 1500 gph pump, w/2nd 780 gph pump. Softened well water used for fill.
    357's Avatar
    May 2013
    SE Michigan
    15
    I think I found it per this site:
    http://www.unitconversion.org/concentra ... rsion.html
    Based on 1 gallon = 3.78541 Liters
    0.1891 grams per 3.78541 Liter = 50.012022343 ppm
    That should be close enough for government work. Now, how to measure .1891 grams of granulated CYA?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by 357
    Your handle begs the question for me....are you a re-loader? I would think if you were, your powder scale would have been foremost in your thoughts. I have one and that's how I would do it. Do you have a friend that re-loads, or someone else that's a Jeweler or into Jewels/precious metals? If so they may have a scale that would do.
    Essential Links:
    357's Avatar
    May 2013
    SE Michigan
    15
    Quote Originally Posted by Brushpup
    Brilliant idea. I don't reload. I've been looking into it as I can't get ammo in my neck of the woods. I've had some on backorder for months now. I'll have to ask my friends who reload if they could hit that specific of a mark. Thanks for the idea!
    The precision required to achieve a useful CYA reference solution really calls for specialized lab equipment and lab grade chemicals.
    357's Avatar
    May 2013
    SE Michigan
    15
    0.1891 grams of CYA needed per gal of distilled water to get 50 ppm.
    Per: http://www.onlineconversion.com/weight_all.htm, 1 grain = 0.06479891 grams
    0.1891 grams / 0.06479891 = 2.918258964541225 grains
    Most of the reloading scales I've seen online are claim accuracy within 0.1 grains. So in theory you could add 2.9 grains of CYA to a 1 gal jug of distilled water to make the 50 ppm test solution but as JasonLion indicated, your results would only be as accurate as your CYA measturements, tools (scale), and jug fill(accuracy to 1 gal) are combined. That's quite a few variables
    If accurate, 2.9 grains would equal 0.187916839 grams.
    0.187916839 grams /3.78541 Liters = 49.69910709 ppm
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    "Take a reading, pour it back in the mixing bottle, shake it up, and try again."
    I use the K2006 too and this is what I do. I do it 3 times, using the same solution... 2 out of 3 wins!
    ~Erin
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
