Results 1 to 9 of 9
Thread: First test with tf100
    May 2013
    Massachusetts
    148
    FC 9.5
    Cc 1.5
    Ta 100
    Ch 250
    Cya 55
    I have been keeping the pool up with just hockey pucks and weekly "shocking" so far.
    Does this seem right? Is it ok?
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
    38,548
    Re: First test with tf100
    Time to stop the pucks and switch to bleach as your CYA is at the top of the recommended level.
    Also since your CC > 0.5ppm ... you need to go through the Shocking Your Pool PROCESS
    What is the pH?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What does the water look like? With a cc of 1.5 you probably need to shock. Stop using the pucks and read pool school.
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    55 CYA is high enough. The unused pucks will keep for years if kept dry. Time to switch to liquid chlorine.
    [center:3aq1mdkl][/center:3aq1mdkl]
    May 2013
    Massachusetts
    148
    What is the pH?
    Ph was 7.2.
    DE, Hayward Filter
    Loud pump
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Ph is ok to start shocking.
    Jeff
    May 2013
    Massachusetts
    148
    Quote Originally Posted by pwrstrk
    Sent from my iPhone using Tapatalk.
    I've never had a problem with bad green algae, but I have had intermittent cloudiness. House came with pool so I'm learning. Water is clean but maybe a tad cloudy.
    I had no idea what I was doing before tfp, just shocking once a week and using pucks as per previous owners instructions, and using test strips.
    I would like to transition to the bbb method.
    DE, Hayward Filter
    Loud pump
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    That's why the cc is 1.5. Read the shocking process and start before it gets worse.
    When you maintain proper FC levels using liquid chlorine you won't have to shock.
    Jeff
    38,548
    You are already using the BBB method. The BBB method is really just about understanding your pool’s chemistry and through accurate testing, adding only what the pool NEEDS and not what someone wants to sell you.
    Cloudy water + CC = shock process
