Thread: No Chlorine Reading
    No Chlorine Reading
    We just got a pool and I have already done 2 test and it doen't show any Chlorine! Help what do I need to do? Someone told me to have a Gallon of Bleach, should I do that?
    38,540
    Re: No Chlorine Reading
    Welcome to TFP!!!
    Please add your pool details and location as described HERE to your signature as it will help us help you.
    You should not add what anyone tells you. You should add what you KNOW the pool needs. To gain that knowledge, you should likely spend some time reading Pool School (button at the upper right of the page).
    What test kit did you use? What were all the results?
    If you have no chlorine, then you certainly need to add some and bleach has the least side effects ... how much depends on your pool size and your stabilizer level (CYA).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Welcome!
    Yeah, what he said ^^
    We need to know the size of the pool. It's really no different than giving cough medicine to a kid - except we use gallons and the drugs use pounds.
