Thread: Test #'s ?
    May 2013
    London Ontario, Canada 1hr NE of Detroit
    5
    Test #'s ?
    Hi folks;
    1st season 100% BBB.
    Green-Black opening to clear and sparkling.......4 weeks. (1st 2.5 weeks at shock level)
    Numbers:
    FC: 2
    CC: .25
    TC: 2.25
    PH: 7.3
    TA: 60
    CH: Vinyl
    CYA: 20-30
    Temp: 74
    CYA will slowly come up with use of pucks.
    Should I raise the TA ?
    Thanks, Dave
    35,000 gal. Vinyl Liner I.G. pool @6yrs old.
    Pump: Jacuzzi. 1.5 HP
    Filter: Jacuzzi Laser250 w/6way valve, 350 lb, 8hr turn-over.
    Mesh Lop-Lok Cover
    TF-100 Test Kit - Pool School - Pool Calculator - Chlorine/CYA Chart
    Always use skimmer socks!!! Aquabot Turbo T.
    38,548
    Re: Test #'s ?
    Looking pretty good ... although the FC is at the minimum, so I would suggest keeping it a little higher.
    Since you are using acidic pucks for the CYA, you should watch the pH and TA so that they do not get too low. They are fine for now.
    May 2013
    5
    Re: Test #'s ?
    Thanks jblizzle.
    Will do as suggested.
    Have a great day folks.
    Dave.
    Mesh Lop-Lok Cover
