Thread: My Intex SWG Is Leaking
    Jul 2007
    Hillsborough, NC
    525
    The cells that make the chlorine are in a short section of clear tubing. It is leaking where this section connects to the main part of the generator. I tightened the clamp on it down as much as I could but it still leaks. Has anyone else had this problem? How did you fix it?
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Re: My Intex SWG Is Leaking
    first guess is o-ring needs replaced
    John Rogers
    24 foot above ground, 13500 gallon, Hayward Power-Flo LX (70 GPM) with 1.5 HP Motor, 18 inch Pentair Sand Filter , Chlorine
    Jul 2007
    Hillsborough, NC
    525
    That seems likely. Any idea what size it is? I'd like to have it on-hand when I take the generator out. I can't find much on parts descriptions for the generator. Right now I don't have a way to by-pass it so the pump has to be off. Although maybe I should add a by-pass some day.
    i have no clue as to what size it can be..Sorry
    John Rogers
    Jun 2012
    Central Alabama
    55
    Do you still have the manual? Is so, it should tell you in it. If not, maybe Intex website. If that doesn't work, let me know, I've still got my manual.....somewhere.
    Intex Ultra 16x48
    Intex 2650 Sand Filter
    Installed June 2, 2012
