Results 1 to 8 of 8
Thread: Fc 0?????
    Fc 0?????
    Hello I Have Been Testing And New To BBB Method But My Cc Is .5 Fc Is Zero. Water Is Clear.
    Ph 7.3
    Ta 80
    Ch 200
    Cya 40
    AG, 16X32, Sand Filter. Trees All Around
    15300 GAL 16x32 A/G
    SANDFILTER
    30,432
    Re: Fc 0?????
    Welcome to the forum. What questions do you have?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Fc 0?????
    Everything looks fine except the FC! Get some bleach/liquid chlorine in there!
    Have you found the PoolCalculator yet? Link in my sig.
    With the 40 CYA, keep FC between 3 and 7, and never below 3.
    You're done SLAMing when:
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    Re: Fc 0?????
    i think he is trying to figure out how is fc is 0 but yet has a cc of .5?
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Fc 0?????
    oh!
    Using the small spoon shaped end of the dipper, add one heaping dipper, or two level dippers, of R-0870 and swirl to mix. If the sample turns pink for a moment and then turns clear again, or if it turns brown, add another dipper of R-0870. If the sample remains clear the entire time, your FC level is probably zero, however it is best to verify that with an OTO chlorine test, since the FAS-DPD test is prone to the occasional false zero.
    Use the OTO/yellow drop test. It is a bulletproof test for the presence of chlorine.
    Re: Fc 0?????
    Thanks For The Input.
    15300 GAL 16x32 A/G
    SANDFILTER
    Re: Fc 0?????
    Quote Originally Posted by Butterfly
    oh!
    Where Can I Get The Oto Test I CurrentlyHaveTheTaylor K2005
    15300 GAL 16x32 A/G
    SANDFILTER
    topher's Avatar
    Jun 2012
    136
    Re: Fc 0?????
    Walmart, Home Depot, Lowes.. Pretty much anywhere, anytime it has two bottles (usually) and is normally labeled pool test it or something like that.
