Results 1 to 11 of 11
Thread: green, black brown, green pool...
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    I didn't have a winter cover for my pool.. (will be buying one this year) and my filter didn't work when the ice melted.
    When I got a new filter (18" hayward pro sand filter 250lbs of sand) dumped some bleach actually about 10 ltrs. of 12%i n the pool, and started the filter, the pool went black within the next couple days. i figured the dirt and stuff on the bottom made it go black, so I used a leaf catcher and ran it around till I wasnt getting any more leafs and been vacumming almost every day. then it went a dark brown/orange color ( i have well water with high iron) last night it seemed to be clearing up.. just foggy, and put some CL in the pool (been keeping CL between 10-12ppm. adding before I leave for work, and when I get home.) anyways today I get home, and pool is a lovely lime green.. i'm starting to get depressed.. been fighting this for nearly 2 weeks now...
    here were my numbers when I got home
    TC 10
    FC 4
    CC 6?
    PH 8
    CYA 25? (could barely see dot at 30) added a few more drops and disapeared - also just added some more on friday. may not follow be showing yet.
    after testing I added ~2L of MA, and 1.5L of 12% CL
    basicly.. am I on the right track? I'm getting depressed, and thinking of just driving a car into the side of my pool or something.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    topher's Avatar
    Jun 2012
    136
    Re: green, black brown, green pool...
    Thought I'd add a pic of my swamp
    30,421
    what does "AC" mean on your test results?
    topher's Avatar
    Jun 2012
    136
    my bad.. I fixed it..
    should of been TC, FC, CC
    didn't notice that
    30,421
    Don't know why my brain couldn't figure out what that meant...Thanks.
    also just added some more on Friday. may not follow be showing yet.
    How much more did you add? Tell us that and we'll start getting you on a good path.
    topher's Avatar
    Jun 2012
    136
    1000g of hth stabilizer
    30,421
    That should bring your total CYA to around 40 ppm.
    Now you must shock the pool correctly. read "How to Shock Your Pool" up in Pool School and follow that article explicitly.
    Your shock value with a CYA of 40 is 16 ppm FC. You must KEEP that much FC in your pool by constant replenishment until your pool is clear.
    topher's Avatar
    Jun 2012
    136
    K, ill retest my cl see where I'm at and add enough to get me to at least 16.. Probably will aim for 20.
    topher's Avatar
    Jun 2012
    136
    Thanks for the advice was able to swim yesterday. First time of the year! Was about to drain the stinking thing and start over lol..
    Casey's Avatar
    SW PA
    10,444
    WHAT?!!! No after pics?!!!
    topher's Avatar
    Jun 2012
    136
    I'll post one in a bit. I was too busy swimming.
