Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: Just Keep Going? My Odyssey...
    ...lived in the city in apartments for 10 years, never had a family pool...
    ...met a girl, moved to the suburbs, inherited HER pool...
    Brief History:
    Uncovered pool for over a year, previous filter broke, pool is green, cloudy, full of leaves
    May 31 starting point
    - me and another first timer put in a sand filtration system. I think it's working...
    - we take a ton of leaves out, and she starts pouring 'mega shock' in the thing like it's nobody's business. Or so I thought...
    - lots of leaves in the skimmer, we pull out when necessary
    - we backwash the pool when we see the water flow slow considerably, I don't think the gauge is working that well, but I don't know
    - still pouring shock in the pool periodically, not much change, I mean I guess pool a bit clearer, but certainly green
    - she takes some water down to the local pool place they give her the following steps:
    ---- put three pounds of powdered shock in, wait four hours
    ---- if it's not blue, put three more pounds of powdered shock in, wait four hours
    ---- if blue, put superfloc in, there were some instructions in the there for the filter too, wait and then the cloud will form a gel at the bottom of the pool, then vacuum up
    - Pool water finally turns blue! I screw up the vaccuum process. Water is green the next day
    - We start the process again, I start hearing all sorts of opinions, shocking, baking soda!
    - I do some research, find this site and a couple of others
    - I decide to try BBB
    - First I go nuts on Borax, 8 boxes to get the pH to the 7.0-7.2 range
    - Then I start pouring bleach in, but clearly it's not the best bleach for this because the water gets sudsy.
    - Pool water starts to clear you can see the steps on the ladder! You can see the big piles of junk on the bottom (well, shadows anyway)
    - but pool water is still mostly cloudy, it's aqua blue and cloudy
    I think this basically takes us to last Wednesday
    I stopped adding chlorine because the readings were so high, I'm thinking I probably shouldn't do that, I had lost the head to the brush/vacuum, so we weren't doing that either
    I'm back to using the MegaShock from Ocean State Job lot, it's 12% per gallon, and it's like $3 a bottle, and I can't seem to find great bleach. I got some from KMart (yeah, who knew they were still around), but it was 8% per gallon and $2 per bottle, and still had some suds, assuming from bleach additives
    Moved good quantities of leaves over the past couple of days, I don't see the shadows at the bottom of the pool anymore, or, I should say these are a lot smaller
    I gave the pool a thorough brushing this morning, I plan on doing that each day
    I want to add three more gallons of shock tonight when it's dark?
    The pool has never had stabilizer added, so I'm not sure if the readings are accurate? Right now it's saying 100 or so, but it's been lower
    Can I assume that the CYA total is going to be warped by the shocking process like the pH?
    Do you guys think I'm on the right track?
    Current status is aqua blue and cloudy (milky white) I can see some shadows where I'm assuming there are leaves, waste product of some sort, but these are almost gone now. The pool starts to get clearer, but then when I move stuff around it gets cloudy again, I'm assuming that's from algae getting kicked up.
    I'm putting more water in right now to get it half way up the skimmer, with all the backwashing and adjustments the water level was in the skimmer, but not that high.
    Just looking for general feedback, thoughts, etc.
    This is an above ground pool, 15,000 gallons
    Thanks!
    15,000 gallon
    AG
    Sand
    Pool is a couple of years old, I think this is the third year
    That's it
    30,421
    Re: Just Keep Going? My Odyssey...
    I am going to be quite blunt...you are NOT on the right track.
    Briefly scanning your post, it appears you are simply tossing stuff into the pool hoping for a positive outcome. That's not what we teach.
    You must give us a starting point that tells us where your water chemistry is. That starting point is a set of valid, current test results....
    FC
    CC
    pH
    TA
    CH
    CYA
    If you will get those for us, we can begin to help.
    FC - 18.5
    pH - 8.0
    TA - 100
    CH - 150
    CYA - 100
    I don't think I'm simply tossing stuff in anymore...but I'm certainly not being very scientific. I just need to know if I need to reverse any processes.
    FC
    CC
    pH
    TA
    CH
    CYA
    15,000 gallon
    AG
    Sand
    That's it
    May 2013
    North East Ohio
    959
    What is the CC, as this is a MAJOR KEY....
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Quote Originally Posted by toofast
    Is the CC the Total Chlorine? I think this is 20.
    First time with all of this...
    15,000 gallon
    AG
    Sand
    That's it
    38,301
    Welcome to TFP!!!
    Also looks like your CYA is much too high ... have you been using any trichlor or dichlor?
    Are you testing yourself? Which kit?
    Try the CYA test using 50/50 mix of tap and pool water to start and then double the result ... this will give you a better idea of how high it really is and thus tell you how much water you should replace to get the CYA to a manageable level.
    THEN, you need to follow the Shocking Your Pool PROCESS
    38,301
    Quote Originally Posted by coachmarino
    No. TC = FC + CC.
    Have you read through Pool School yet?
    pool-school/pool_water_chemistry
    pool-school/swimming_pool_definitions_abbreviations
    No. TC = FC + CC.
    So CC is 1.5. 1.5 (CC) +18.5 (FC) = 20
    I've read all that, but to be honest, I've read so much my head hurts.
    And like many of you, I do have a full time job!
    15,000 gallon
    AG
    Sand
    That's it
    I'm wondering if some of the "goo" you dumped in with your mystery bleach might be contributing to the cloudy water.
    It's not really that hard to find plain bleach, so I don't understand why you would not just once, but at least twice dump bleach into the water that was obviously not "just" bleach - are you trying to make the problem worse or is it just not important enough to make sure you buy the right kind?
    Summer Escapes 15'x42" AGP, Intex 14" sand filter, Intex SWG
    30,421
    I here ya' Coach. You have given us some data to work with so let's just address the CYA for now. 100 ppm (perhaps higher) is w-a-ay too much to successfully manage your pool water. You need to drain a total of at least 50% of your pool water with the goal being to reduce your CYA down to 50 ppm. Do it in a series of drain/refills of about 1/3 testing CYA each time you refill.
    One other project while you are doing this.....when the pool is low, get out all that solid debris that you can....that will help you immensely later when you start to shock correctly.
    I would add nothing else to your pool until your CYA is down around 50 ppm.
    Casey's Avatar
    SW PA
    10,448
    Even if the pool turns as green as Mr. Greenie Face!!! Don't add anything like Dave said.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Like Dave says your CYA is way too high, if your pump supports vacuuming to waste then you can vacuum out some of that sludge on the bottom while draining to replace water to get your CYA down. Also do you have one of the suggest test kits yet, being able to measure your exact chlorine level while shocking is very helpful in completing the shock process in a timely and economic manor, other wise your doing a lot of guessing and back sliding ?
    Ike
    p.s. it is likely that the powdered shock from the pool store was dichlor which raises both FC and CYA
    I purchased a new kit from hth because I didn't feel the idea of draining the pool!
    It's the one where you take the pool water in and then you add the cyanuric acid reagent, mix, and then pour into the tube with the black dot.
    This one read 65.
    Retested everything else too...
    FC - 18.5
    CC - 1.5
    pH - 8.0
    TA - 100
    CH - 150
    CYA - 65
    Thoughts?
    15,000 gallon
    AG
    Sand
    That's it
    38,301
    CYA still on the high side.
    pH should be lowered to the lower 7s and then because the CC are too high, you need to follow the Shocking Your Pool PROCESS
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    I feel your pain, I've been where you are... several times.
    If your CYA is actually 65 then your Shock value would be around FC 26. The process calls for reaching shock value and maintaining that number until the water clears and you pass an overnight test. Since you still have CC of 1.5, there are still organics that need to be killed off. Keep vacuuming best you can to get rid of the leftover debris in the pool. My experience has shown me that things will move a bit faster when the pool is free of the sludge.
    At a CYA of 65, you will need to use more chlorine on a daily basis and a large amount if you need to shock again. It is with that in mind, that a partial drain was recommended. While 65 is much better than 100, it still is a bit high... but that is up to you if you want to drain some to make it more manageable.
    I open a swamp every year. It has taken me as little as two weeks and as long as 5 weeks to clear, depending on my diligence to the shock process. I have a brand new pool cover in a box on my front porch for three years now... maybe this will be the year I am smart enough to get it on the pool.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    38,301
    Quote Originally Posted by dattia
    Actually, on a maintenance basis, the higher CYA results in less loss to the sun, so while the actual required FC level is higher, you end up using less each day. The problem is that the shock process becomes more painful at the higher CYA levels.
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Thank you for the clarification.
    27' round AG
    Should I add muriatic acid?
    15,000 gallon
    AG
    Sand
    That's it
    38,301
    Sorry, since you FC > 10ppm, the pH reads artificially high (as I overlooked) ... so you are likely fine to just continue the shock process.
  20. Back To Top    #20
    Thanks for all of the advice, and the patience...
    I think despite all the false steps I might be on the right track.
    The pool still has leaves and residuals in the bottom. I got the vacuum going tonight the best I've ever had a chance to. There were a ton of leaves in the skimmer and lots of ****e moving around, a few clouds picked up.
    I have had trouble finding really pure bleach. Best I found was the stuff at KMart, there were suds, but only for a bit, not nearly as many with the Chlorox. The Chlorox was some classic version...oh well.
    Can anything cause my CYA to go up more? I'm pi$$ed that the powdered shock we used may have caused that problem. There was literally no stabilizer prior to using that.
    For now it's just test levels, add chlorine, to keep that FC level high, and continue to vacuum and brush...
    First time through, I have to admit this is hard work. I guess it's only been 2 and a half weeks...
    15,000 gallon
    AG
    Sand
    That's it
