Draining help to get rid of cya
Erdo
Jun 12, 2013
12
Hello all! My cya is around 160-180 with dilution testing method and I need to drain about 70-75% of my water. I want to do this drain in 3, 25% drain increments due to me having a vinyl liner. I don't have a submersible pump but I do have the multiport valve. What is the best way to drain 25%? Should I close off the deep end skimmer and the main drain or one of them? And what about the shallow skimmer? Is it possible to close the deep and shallow skimmer at the same time? I can then set the multiport to waste correct? I'm confused and am wondering what my best approach would be without the submersible pump. I have attached a picture of my skimmer and main drain lines.
Sent from my iPad using Tapatalk HD
Make sure you leave a ft of water in the shallow end so your liner doesn't float up causing wrinkles.
What is your target CYA level? Three 25% drains do not equal one 75% drain.
Assuming 170ppm to start, a 75% drain would take you to 42.5ppm
using 25% drains would give you: 170*.75 = 128ppm ... * .75 = 96ppm ... * .75 = 72ppm ... * .75 = 54ppm ... * .75 = 40ppm
So it will take five 25% drains to get to the same ppm as a single 75% drain.
