Results 1 to 7 of 7
Thread: My Success Story. Before and After Pics
    Just wanted to post my thanks to all contributors who helped a Newbie Lurker get control of his pool. Had major algae bloom and threw a bunch of chemicals into it with no real scientific approach. With no success, I admitted defeat and came here for advice. Learned my basic pool science, followed the shock thread (Thanks JasonLions) and developed some patience.
    Of course, similar with other stories, the key to my success was getting a good test kit. I think it has already paid for itself (TF-100)
    Determined my shock levels with the charts (I was not even getting my FC CLOSE to real shock levels prior to that). Kept my FC at about 23-25 for 4 days, often required shocking twice a day. I saw almost NO results for the first 48 hours, but just kept my chemistry right and kept brushing the pool. I got a little impatient and went and bought some DE to speed things up. I started seeing better results right away.
    Now I am at day 6, my pool is sparkling clear, and my FC is around 21. I did a chlorine drop test last night after dark (FC 23) and fell to 21 early this morning. Should I hold on adding more shock at this point and just keep checking my chlorine drop overnight? If it drops less than one overnight, I can stop the shock process, right?
    Pics at day 1[attachment=1:34yoqwag]IMG_2472.jpeg[/attachment:34yoqwag] and day 6 [attachment=0:34yoqwag]photo.jpeg[/attachment:34yoqwag]. I have some slight metal staining on the front ledge that I will eventually use ascorbic acid on... but that's for another day.
    thanks to all for your help.
    10,000 gal IG Trilogy Fiberglass (16X32) with 16 inch deep upper wading pool with 3 spillways to pool Intellichlor SWG, 2 HP Sta-Rite Max-E Pro pump. Pentair Tegalus Sand Filter. Hayward Heat Pump Glacier Pool Chiller, Pool Cleaner 2 Suction cleaner.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: My Success Story. Before and After Pics
    Welcome to tfp, Moodyerdoc
    When I first read you post and looked at your pics, I thought you still had green water...then I figured out that your pics are day 6 first and day 1 second
    Quote Originally Posted by Moodyerdoc
    Keep it at your shocking level until your Overnight chlorine loss test (OCLT) is less than 1 ppm, your cc<0.5 ppm and your pool is crystal clear simultaneously.
    Jenischmeni's Avatar
    May 2013
    Indiana
    91
    GREAT job! Congrats.
    You have a beautiful pool!
    Central Indiana, 7200 gallon, IG fiberglass, L250 Jacuzzi sand filter, Hayward H150 gas heater, Pentair fiber optic light - installed '06. AOSmith 1.0hp pump, CPSC-24 SWG - installed '13. TF-100 Test Kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    Welcome!
    Yes, keep it up there. You want it gone for good, don't leave anything left to come back.
    And now you can get into some other threads and repeat that perfect line of yours, "the key to my success was getting a good test kit. I think it has already paid for itself (TF-100)"
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good for you and welcome. On the right track and you are nearly there. Pass the OCLT and make sure you are done according to the "how to shock your pool".
    Essential Links:
    thanks everyone. Goodbye pool store guy.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    SEEYA!!!!
    Essential Links:
