Thread: still new and lost
    Jul 2012
    Northwest Alabama
    51
    still new and lost
    hey guys last year was pretty easy keeping up the pool sence it was new ......now that it has went through 1 winter in north alabama its still cloudy and it want clear up using my filter ...my readings from the tf100 kit are as follows TA=40....PH=a little less than 6.8 but its real close to 6.8.....and calcium hardness =60
    CL=0(which i know how to fix)
    CYA=0.........i know cya and cl go together but what would yall have the other numbers set at i have a 14-48 ultra frame intex ....once i get my water clearer i will be adding salt for my swg
    thanks for the help
    Chris
    intex ultra frame 14x48 round ag, intex swg, tf100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: still new and lost
    To clear it, you need the shock process.
    I'd use borax to raise pH a notch. List 6.8 now, aim for 7.4 That will also raise TA a little. CH doesn't matter to a vinyl pool, so ignore it. http://www.poolcalculator.com/
    While the Borax is dispersing, measure out enough CYA to get you to 30, tie it up in a sock and suspend it in the pool in front of the return.
    Recheck pH. If it's at least 7.2 but less than 7.8, go!.
    Raise FC to 13 and keep it there by replenishing the bleach every couple hours. Don't forget to brush the walls, and drag out as much organic debris as you can, if there is any on the bottom. You can ignore everything but FC and CC while you're up there at 13 FC.
    And post pictures.
    Jul 2012
    Northwest Alabama
    51
    ok thanks ill start with the borax and CYA ......i work a evening shift so my days are short other than mornings lol
