Thread: Calcium scale? Not sure of my problem.
    Jun 2010
    MI
    36
    This whole thing started with a leak that developed last year. At one point I was losing an inch day. I had to add a lot of well water which has a very high iron content. I didnít notice too much staining last year but did see some early signs of it. This spring I had to add about 3000 gallons from the well to get everything up and running. Fast forward- I had the leak fixed at the end of April and I figured I was good to go. Got the pool cleaned up and nice and clear-good levels on all accounts, but I had metal staining on my two year old liner. I read all about the AA treatment and went ahead with this approach. I couldnít find any place locally to buy AA and the pool store had never heard of it, go figure. I ended up getting Natural chemistry stain free and the liquid metal free as a follow up. I assumed stain free was just AA in a fancy container.
    So I let chlorine drop to 0 PPM and put in 1 ĺ lbs of the stain free and a couple hours later added the metal free liquid. It did remove the dark greenish color that was staining the liner but now I have a very rough feeling liner, some sort of scaling. It is on the walls and the floor and can be scrubbed off with a generous amount of elbow grease. It comes off the walls easier than the floor. As it scrubs away it looks like little tiny salt particles. It feels like you are walking on sandpaper in the pool. It is at its worst where the metal stains were at, in the corners and along creases. In these areas I canít even scrub it all off. This was my first time in the pool for the season so Iím not sure if the coarse texture was there before I did the metal treatment.
    I have not had any issues with levels that were out of wack as far as PH being high and causing calcium scaling. Based on my research on this site it sounds like calcium scaling but doesnít make sense that it would be the worst in the areas that had metal stains.
    Once again I need advice on what I should do and what the problem might be I have included a set of numbers from today. If you tell me to scrub it off what is the best way to do this since I canít be under the water long enough to scrub areas that need it. The regular pool brush isnít abrasive enough to do the job; I have been using a green scrub pad. Itís a vinyl liner and draining is out of the question right now, ground is way too wet.
    Thank you in Advance.
    PH 7.6
    Fc 3 I know its low, the metal treatment said not to go too high the first few days after treatment.
    CC 0
    CYA 40
    TA 110
    CH 270
    16x32 19,000 gallons vinyl liner IG with vermiculite base, 2 jets, 1 skimmer, 1 floor drain, Hayward s-200 sand filter with Pentair superflo 3/4 HP single speed pump , liquid chlorine.
    Jun 2010
    MI
    36
    Re: Calcium scale? Not sure of my problem.
    Anybody?
    22,553
    If your pH was high over the winter it's possibly scaling. Keep your pH close to 7 and it should slowly go away.
    24' x 52" Round AGP. 2hp/ľhp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    30,432
    +1 what bama said.
    Meticulously control your pH down around 7.0 (no higher) and you will start to see it reduce and go away. It'll take awhile.
    Jun 2010
    MI
    36
    Will do. Thank you.
    Jun 2012
    DFW, TX
    25
    Quote Originally Posted by mtw826
    Will do. Thank you.
    Any luck with keeping pH low?
    22,000 gallon - cartridge filter - IG plaster (rock waterfall) - Pentair IntelliFlo VF Variable Flow High Performance 3HP Pool Pump - 16A 230V
