Thread: White flakes at bottom of pool-Pentair IC40
    Mar 2013
    rancho cucamonga, ca
    10
    Pool is 11 months old, white flakes have been collecting at the bottom for the last 3 months and increasing in quantity. Called the builder out this Saturday, cleaned the IC40 again along with the filter and still had flakes Sunday morning. Builder says it's normal and more visible because of the dark bottom pool (Quartzscape). Chemistry is good, adding acid occasionally but everything else seems about right. I'm not buying that this is normal but not sure what the issue is? Thanks in advance.
    18,000 Gallon in ground salt pool and spa, Quartzscape, Pentair Easy Touch, Pentair IntelliClor IC 40,
    Pentair Quad DE Filter, Pentair 400,000 BTU Heater
    1 Pentair IntelliFlo VS pump, The Pool Cleaner Sweep
    Re: White flakes at bottom of pool-Pentair IC40
    I have the same problem, same equipment . pool is 2 years old. go to three pool stores get three different answers! Help !
    9 ft x 18 ft x 52 in Intex Ultra Frame
    1,200gal Intex Krystal Clear™ Sand Filter Pump
    Hayward Wide Mouth Skimmer MODEL SP1090WM
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    More than likely it is calcium collecting on the cell and flaking off. What is the CH reading of your water?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I had the same issue, until I properly balanced the water. It is caused by scale building up in the SWG and discharging into the pool. If you keep the CSI index at or very near zero it will stop. For mine that requires very close monitoring of pH and TA. Now I don't even have to clean the cell. When the indicator comes on I just inspect it and put it back.
    chiefwej
    Mar 2013
    10
    I'll try to post the numbers tomorrow. I don't have CH or CYA numbers, guess I'm gonna have to get a better test kit.
