Thread: How necessary are UV filters?...
    Jun 2013
    central texas
    27
    We are in the process of getting bids for our backyard pool and so far UV filters have been an optional item. Some builders give long sales pitches and recommend them others just include them in the quote (still an option) but don't discuss it. They run around $1500. Is this something we need? Rather use the money on a larger pool if possible...
    19,700 gallons non SWG
    Pentair DE quad 100 filter
    Auto chlorinator and nature 2
    Inground pebble
    Intelliflo variable speed 3 HP pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How necessary are UV filters?...
    Welcome to TFP!
    Not necessary at all.
    I'd consider them almost useless unless your pool is used regularly by people you don't know well or you expect wildlife to make use of it.
    Jun 2013
    central texas
    27
    I was told UV filters use less chlorine so they pay for themselves in a few years. Untrue?
    Inground pebble
    SW Indiana
    9,199
    Quote Originally Posted by Freakaloin
    Actually, the UV system may use up some of your chlorine itself.
    Though the UV does sanitize the water as it passes through the unit, the sanitizer in the pool is what prevents person to person transmission of pathogens. When something contaminates your pool, it could be 8 hours or more before that contaminant passes through the UV sanitizer.
    Jun 2013
    central texas
    27
    Thanks man! We will definitely put that money to better use now!
    Inground pebble
    Isaac-1's Avatar
    SW Louisiana
    6,711
    There might be some situations where UV systems decrease the use of Chlorine, but I suspect most of these would involve a pool that was already out of balance, in a correctly balanced pool you will see the benefit to them to be minimal and they will increase Chlorine consumption as Chlorine breaks down under UV light.
