Thread: Help with salt pool
    Help with salt pool
    Hello! We recently converted our above ground Easy Set pool to the Intex Saltwater system. I am having trouble getting it balanced. Here are the levels as of this morning:
    volume - 5900 gallons
    Salt ppm - 3000
    Hardness -100
    Total Chlorine - 0
    Free Chlorine - 0
    ph - 8
    Alkalinity - 40
    Stabilizer - 0
    I am in TN - the temps here average 80-90 daily.
    Any help is appreciated! Thank you!
    23k Gallon, IG, Vinyl, Hayward Perflex 65A DE Filter, Heat Pump, In-Line Chlorinator, Pool Installed 2010 (however i just bought the house with this pool 1 month ago)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Help with salt pool
    Welcome to tfp, rivesfamily
    Have you read this pool school article?: http://www.troublefreepool.com/pool-...ater_generator Likely, you need to get some stabalizer (cya) to keep your chlorine produced by the Intex Saltwater Chlorine Generator (swg) from disappearing to the sun.
